Results 1 to 15 of 16
Thread: blue lights?
    Oswego, IL
    1,858
    blue lights?
    anyone ever put them blue car lights into a 350x headlight or somthing?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Jun 2004
    Oregon
    1,784
    well I dont know about your 350X but ive seen them on banshees!! And if i owned a 350X id wanna use something like that inplace of the duel lights....
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    can someone post a pic of these lights?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Corry,penn
    40
    I put one of those lights on my 200x .Make sure you get the right wattage for your stator.They look cool as hell.
    DON'T MEAN A THING IF YOU AINT GOT THAT BLING! 1984 200X
    Jun 2003
    Lake George, New York
    1,732
    Do you mean the blue light bulbs, or the neon type lights that go under the cars and light up the ground? If you mean the light bulbs, yes it can be done, but they burn hotter, there fore you will burn them out faster, and if you put them on somthing liek a rincon 650, you will burn the plastic headlight out....
    Oswego, IL
    1,858
    im talking about the bulbs it wont hurt a 350 light wil it?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Jun 2003
    1,732
    Yes, the bulbs will work, but I believe they're like 5 more volts apiece, so im not sure how long the bulbs or your stator will last. I know they blew like crazy in my sled, and they suck, but thats just MHO
    Oswego, IL
    1,858
    they dont make them in a 12volt isnt that what the 200x is?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    the 200x is a 12 volt and can handel 60 wats at the headlight
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Las Vegas, NV.
    2,537
    It's like daaaang! Those would be sooo cool on a trike. Maybe while you're buying those at Pep Boys, you can find some chrome european "twin-row" windshield wipers, a fake cellular phone antenna, & an 8" exhaust tip for your trike as well. All of those hop-ups combined would be good for at least 4-5 horsepower.
    Oswego, IL
    1,858
    wtf red rider just cuz i want some cool lights u gota be a jerk
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Las Vegas, NV.
    2,537
    Vartiak, don't take my response as a personal attack on yourself. I see those blue lights all the time in all of the teenager's lowered Acuras, Hondas, Nissans, & Toyotas, and I think they look weak. They look so fake because they are trying to make their headlights look like those HID (High Intensity Discharge) lights found on the high-end Acura, BMW, Infiniti, Lexus, & Mercedes cars. The HID lights are a totally different technology than those "blue color-coated" lightbulbs. The blue color coating actually restricts the light output, making it a dimmer, less illuminating light as compared to a standard headlight, and the standard headlight is no match at all for a HID headlight. I'm just voicing my opinion, albeit in a sarcastic manner. What it really comes down to is, if you think they look cool, then by all means, go for it. Are we cool now?
    Corry,penn
    40
    hell ya, were cooler than cool we drive trikes
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    what i think, you can put the lights in there if you find some to mount properly and are able to wire them up. and like you said the 200x can handle up to 60 watts, this i don't know for sure. one thing is and is true with all things, it's only gonna be as good as your weakest link. now the 350x headlight is set for 35 watts. you put a 60 watt bulb in there and it's gonna get so hot and start to melt/deform the light housing. all together i dont think its a good idea unless you can find some low wattage bulbs for it.
    Howard
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    >->->->Hgoody77@yahoo.com
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    ok,,, now there is an easier way!!! i can't believe nobody has mentioned it yet, you get a single blue L.E.D. DRILL A HOLE IN THE IN THE BACKSIDE OF THE HEADLIGHT PLASTIC AND STICK IT IN . it will make your headlights look real blue without rigging up some different bulbs . then you can use any color you want,, and keep your oem stuff intact,,,
