there now it is right. if i put a straight pipe where the converter is will it make my emitions black and stuff
no, but if your car has to be tested for the emissions then it will fail.
02 raptor
01 lakota sport
85/86 tri-z
it will?? i swear that catylattic converter is useless, it is a concept that was later discarded after they realized it was useless right?
The below sentence is TRUE.
The above sentence is FALSE
we were workin on a 95 s10 and the only place you could get one was from Gm and it was expensive. we just ran a striaght pipe thru where it should be.
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
I took mine off my 89 truck and put a piece of "test pipe" in its place. I went to Speedy muffler and got a quote of upwards of $600 to replace my cat. Hell, $15 for the test pipe, some of my old man's muffler clamps, about 25 minutes to cut the old one off, and put the new one on, and we're good to go.
96 Warrior - 90 Moto4 - 86 Big Red - 85 Yamahauler - 84 Yamahauler - 82 Big Red - 79 Trail 90
I would get rid of my cat...unless it's a newer vehicle that has the O2 sensor in the cat....then you have to figure out other ways around that....
Trikes:
1973 Honda ATC70-orange!
(2)1985 ATC70
1985 Big Red 250
1985 250R
my cat has a o2 sensor on it what if i unplug it???
what kind of car is it and what motor is in it
I would like to know to!Originally Posted by atcpunk107
Warranty on emmisions stuff are 10 years 100,000 miles. So if your car qualifies take it to the dealer for free warranty work!![]()
1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
1984 Honda 110 ATC, orignal blue plastics,
1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
Honda US90 ATC, Collecting Dust
2004 TRX450R
If it's carb. you could unplug it but you might have to unplug the ECM.Originally Posted by yamahaman89
If it's EFI leave it connected. If you disconnect the engine could run rich and loose MPG. Because I believe if the ECM doesn't detect the O2 sensor it goes into open loop and make the engine run rich. Or it could run lean and burn a piston and it's reuild time!
2004 TRX450R
its a 95 chevy blazer S10
You could run it without the cat but you'll have to drill a hole in the pipe and then weld a little nut or something for the O2 sensor to screw into.
If you do this unplug the battery so the computer well have to learn motor again and your engine light should hopefully not turn on.
You can go to S10forum.com and ask their.
2004 TRX450R
