Results 1 to 15 of 18
Thread: Keyed ignition
    Apr 2004
    International Falls Minnesota
    546
    Keyed ignition
    Is it possible to put a keyed ignition on a 84 200X. I would like to have one because im worried some trailprotrailprotrailprotrailprotrailprotrailprotrailpro kid is gonna jump on it when im not lookin at someones house and take it for a spin. And as antitheft device.
    Rittman, Ohio
    6,276
    Just use a tether kill switch.
    Apr 2004
    546
    Wont work i want a key so i can take it out and not worry about anyone starting it with out me saying they can.
    Rittman, Ohio
    6,276
    Do you know what a tether kill switch is? You pull it off and take it with you. They cant start it unless happen to have another switch cap that fits.
    Apr 2004
    546
    Oh ok i thought you were tlakin about the type on a snowmobile. Lol i feel like an idiot now.
    Apr 2002
    s.w. michigan
    6,498
    Quote Originally Posted by 84honda 200X
    the black wire on the left handle bar control is the one that you should use to wire in a key switch or tether ( or a toggle switch for that matter ).
    i think if you was to use any other wires to shut it down you might run the risk of screwing up the c.d.i. box .
    john
    Goderich, Ontario
    125
    He is talking about the type used on a snowmobile. I had one on Arctic Cat that I sold this spring. They are only about $12-20.
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    my friend has a tether switch on his banshee, we started it without it because all it is a button, you just have to push it in, you can buy a small key from a hardware store, for like 20 bucks, just wire it to the same wires as your kill switch, just put it somewheres on the bike that isn't really noticeable like behind the headlight, or under the gas tank or something. that's what i'm going to put on my 200x. my friend's banshee, has the same thing, i have one on my 185s too. and i know a few others with banshees that have it also.
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    leprogle's Avatar
    Mar 2003
    New Brunswick
    345
    by small key, i mean an ignition switch
    Caution
    Michigan
    1,220
    Quote Originally Posted by TimSr
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=2483743006
    I believe this is what TimSr is talking about, I use these on all my bikes and you take the tether with you like a key if you want to keep people from riding your machine.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by x.system
    You are correct that is what Tim Sr was talking about. How ever I wouldn't pay $9.99 for shipping on something you could ship Priority Mail for less than 1/2 of that.
    Howdy
    Apr 2004
    546
    So just take the switch box witht he lights and on off switch and take the black wire out right and wire it to an ignition? I think thats waht you guys mean i think ill put it under the air scoop on the tank.
    Rittman, Ohio
    6,276
    This are made to mount to the handlebars. They are required for racing. The idea is you hook the other end to yourself, and if you unexpectantly exit the bike, it pulls the cap off and it kills the bike. The easiest way to hook them up is to ground one wire of the kill switch to the frame, and hook the other to the input wire to the coil. This input to teh coil wire is usually on a spade connector, so all you have to do is stick the bare end wire in the spade connector and then plug it in. No soldering or splicing required. When the cap pops off the coil input is grounded, and you lose spark.
    Oswego, IL
    1,858
    then what would we do with the light buttons? is there a way i can take a switch i have and connect the wires to it and make it work?
    1974 atc 90 project underway cuzzztom
    1985 atc 110 for sale
    84 200s all original got off the first and only owner
    new carb
    maybe putting my 200x cam in it but not sure
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Apr 2004
    546
    i was gonna just leave the switches alone but reroute the ignition wire. Leave the light switches where they are.
