Hey guys, I've had my '87 Big Red for about a month now and it's about time to change the oil. Do you recommend the standard Honda 4 stroke oil or something else? I was just curious if yall used something else for your Big Reds or other trikes.....
i like to use honda oil.it's not to expensive , around same price as a quality auto motor oil.
1985 250ES ATC
1985 200X ATC
1984 250R ATC
1983 LT-50
1991 LT-80
1996 YFB-250
>->->->Hgoody77@yahoo.com
I run quaker state peak performance 10w30 in all my trikes.
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
I use Amsoil 10w40 for my 350X.
R.I.P Raven
2006 Yamaha Banshee Special Edition
1996 Honda CBR 600 F3
we use penzoil 10w40 in are trikes and bikes
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
i'm sure you know this but just in case you might not ,,,, be sure to change the oil filter in you es also.
john
Oh ok, thanks for the feedback...I will probaly use the K&N oil fliter...I heard they were pretty good??
hi i also have 85' bigred 250es where is the oil filter i can only see air filter thanks
I use honda oil in all my atvs and when servicing others. Good oil for the price plus thats were I get my filters.
There is Nothing too nice to be hot rodded
85 250r (On going build up and rebuild) Ported Cylinder, 36mm carb, New Crank, Rod and Piston FMF Exhaust (for now)
04 400ex, Duncan Racing Exhaust (,wifes)
80 Z-28 (5 year + 10 to 1, Full Roller 427 + .060 (440) build up ) 475 hp at the rear wheels running 7.22 1/8s on old slicks.
