Results 1 to 2 of 2
Thread: Adjusting 200x rocker arms??
    Southern MN
    1,875
    How do you adjust the rocker arms on a 85' 200x? I know they have to be gapped at .008mm, but are you supposed to gap both arms at TDC? All you do is loosen up that little bolt, then slide a feeler guage in there, right? If anyone can explain the whole ordeal, it would be greatly appreciated. Thanx again.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Wink heres how
    The piston does not have to be a TDC. The rockers arms just have to free from touching the valves. After they are free take a 10mm ( i think) socket and losen the nuts and fiddle with the screw till it is at .008mm. Just be careful when losening the nut and keep a good grip on the wrachet so it doesnt twist the rocker arm. Also make the adjustments when the motor is room temp. Easy at that.
