Thread: Cleaning motor
    Jul 2004
    Baton Rouge, LA
    946
    Cleaning motor
    Just wondering how yall clean the outside of the motor/crankcase/head? I have a layer of dried on dirt and mud on mine....what's the best way to get that motor looking good again?
    Mar 2003
    Barnesville,Ohio
    2,298
    wet it then let it set for 10 mins...repeat....then pressure wash it away if if wontcome off very good. if its easy to get off then just pressure wash it off
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    May 2004
    SOuthen CALifonia
    138
    Spray it down with Simple Green or Orange Blast/Grease Lightening, or Castrol Super Clean, let it sit for a while then spray it off (high pressure is best).
    Good luck!
    Jul 2004
    Baton Rouge, LA
    946
    Oh ok, I'll try those cleaners on it....I tried using an electric powered pressure washere but it didn't do so good...might have to try a real one.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Use castrol superclean in a squirt bottle, DO NOT DILUTE IT! Spray it, let it sit atleast 20 minutes, squirt with water hose, repeat if nescarey. Once the bulk of it is off you can use an old sponge with superclean to get the film off. Be careful where you put the superclean once the surface is clean though, it can and will take paint off.
    Jul 2004
    Baton Rouge, LA
    946
    That sounds like it will work, I'll get some of that superclean stuff....thanks a lot.
