Z question
Hey, I just changed my gas oil mix to 40:1 and my question is. It seems that since I have changed the mix when I ride the bike will ride normal first starting off in low rpm but when you gas it even a bit it will rev really high almost like the powerband but at a much lower rpm than before. Is this a common thing when you change your gas oil mix or is something maybe wrong somewhere?
Whenever you change anything that affects the motor, you will want to do frequent plug checks for a while. If there is a problem, it will show on the plug. Depending on what mixture you were running before, you might have to make carburetion changes, which, again, your plug will tell you.
//ArrowChat Integreation Code
