Results 1 to 7 of 7
Thread: 85 Atc250r Question
    Jun 2004
    Oregon
    1,779
    85 Atc250r Question
    HEy guys! I just tore down a 85250R, painted the frame and rebuilt it back up..Before i did all this it ran awesome! But now im fouling plugs left and right!! And its just not fouling its flat out BLACK! IT smokes pretty bad when im riding and leaks oil out the header but it has tons of power for a stock bike It pulls wheelies in 4th with ease...After about 2 hours of riding it starts to bog down and then dies. I change the plug and then its rocking again.. Everything in the bike is stock as far as i know..Its running a stock carb with a 142 main @40-1 running Klotz oil and a B8ES plug..My needle clip was on the 3rd notch when i put it back together..The book says it needs to be on the 2nd i think, but wasn't sure if one notch would make it run that rich,and i didn't know if it was 2 notchs from the top of the needle or the bottom.. I dont think my rings are going it has good compression..I just bought a paul turner high rev pipe and im trying to get the thing running good before i bolt it on..Any info would be great!! THANKS!!
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Michigan
    1,220
    Move the clip to the second notch from the top and do a plug chop. One notch will make a difference and it sounds like you are getting to much fuel.
    Jun 2004
    Oregon
    1,779
    What the heck is a plug chop hehe?? And if im fouling plugs that means im getting to much oil right??
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Jul 2004
    Minniesota
    115
    ya getting to much oil if its black
    wales..uk
    1,318
    check your gearbox oil....if it uses alot...it could be the centre crank seal...
    they go hard after a few years..then drags the oil through the seal and into the bore....change your spark plug for a new one...if it starts sweet and then chokes up after a few hours...it's a good chance it's the crank seal...hope this helps
    Rittman, Ohio
    6,276
    Carb settings dont suddenly go out of whack for no reason. I would strongly advise not adjusting anything in the carb, until youve figured out what caused your sudden carburetion change.
    What does "tire down" mean? Did you change anything in the motor, exhaust, carburetion, intake, or fuel mix? Was the engine disassembled? If it ran fine before, then something has changed, and while it may be inadvertant, I doubt your main jet or needle clip changed themselves. The only thing in the carb that could cause such a sudden and drastic change is something failing within the choke circuit.
    Jun 2004
    Oregon
    1,779
    all we did is tear down the frame and paint it thats it...but we took apart the carb and think we might of put the needle on the wrong notch..we had it on the 3rd and its supppose to be on the 2nd..Also i talked to a guy at white knuckle racing, he said the paint may be covering up my ground and given me bad spark resulting in fouling plugs so ill check that out too...
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
