Thread: adjusting float on carb.
    Jul 2004
    Mud hill. close to water !
    3,658
    Got an 82, atc 200 in the garage that i'm stealing bolts from for my big red at the present time... but i want to restore the old beast for friends to ride this winter.
    I've had the motor running, but it ran like crap...
    An inspection of the gas tank revealed a mountain of rust, and orange gas, flushed it out like 10 times with methyl hydrate and a handfull of washers before it started to come out clear...
    Then ended up with pinholes in the mofo that were sealed up with silver solder.. still chasing more holes now.. but that's another story.
    The carb was opened by a " friend " ... and cleaned, it had orange rust pile at the bottom, and really dirty... got it clean as a whistle but i know he played with the float level....
    how do you adjust the float on these carbs.. any thicks to this ?
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    they are not adjustable.
    Jul 2004
    3,658
    Hmm..
    The float mounts on a pin to the top part of the carb.. it's attached by a thin metal arm , and slightly bending this will make the float sink or float at a different level affecting the overflow if i undersood correctly
    Not meant to be an adjustment.. i know..
    However.. it's happened already.....
    Jul 2004
    Okla.
    75
    You need to call trailprotrailpro dealer and ask how high to set the float....then get a ruler and measure from the gasket surface to the top of the float....bend the little tang that presses on the needle only ....do not bend the arms of the float....And make sure that the float is just touching the needle,,,,not pressing it down when u take trailprotrailpro measurement.....If you have any questions you can email me at Matthew161320@aol.com for the fastest answer....
