Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 87
Thread: Sanding/restoring plastic. How to guide
  1. #46
    1985 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    Olean, NY
    335
    I've noticed on some of the fenders I've done that there is a layer that is almost like it has been hardened and unless you get through this layer it will not turn a nice red and will have the whiteish tint to it. I used a razor blade to scrape this layer off DO NOT DO THAT though it took forever to get those scratches out. I think you just have to sand through this layer.
  2. #47
    Mar 2003
    Kansas
    1,507
    On some fenders, it wont be possable to restore them. On ones that have layers and layers of sun fade... by the time you get off all the crap on top sanded off, there wont be a fender left. Thats a given.
  3. #48
    leroy, new york
    1,025
    IS there any way to fix deep scatches and to make it look good.
  4. #49
    Nov 2002
    Chezzetcook Nova Scotia
    1,837
    This is not advice. Just what I do to my plastics.
    When you get really whitened plastics use a flat paint scraper and be very easy.
    Once you do this a few scrapes you will know how much force you need to take 90 % of the bad plastic off.
    Im in the midts of sanding down my rear fender and im glad I did this. Ive spent 10 hours on half of my rear fender. As for welding plastics it way easier then you think. I had a thick branch come right through my front tecate fender and wedged between my ehpansion pipe and frame. Destroying my mint fender. or at least a huge hole. now when it broke it also bent the piece that broke. All you need is a heat gun and a weller sodering gun with a cutting tip. All you need is a long thing piece of same color plastic to use as a brazing rod and melt the rod with the heat gun and let the molten plastic drip down onto the welded area. use the weller sodering gun to cut out dirt out of the plastic. My front fender is mint or as mint as it comes. and it is strong. my bike was droped on a tail gate and landed right on the bottom of my front fender, and it did not break.It actually held up my bike. I sheet you not. and the heat gun can also be used to take out white (bend) marks. welding plastic is no more harder then sanding them. Just dont rush.
  5. #50
    Back in Happy Valley
    833
    I know this post is old news, but i tried to do this today, and i guess i didn't go long enough with the 2000 and not in enough directions, mine has little scuffs in it still and are holding in the compound. Well actually i only have meguiars cleaner wax (not very abbrasive) I'm gonna swing into the parts store and get some good stuff. Also i started with 600 is this too fine? I dont have anything huge as far as scrapes, i think i just rushed it...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
  6. #51
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Tecate250
    Now this is something I'd love to SEE step by step pic's or better yet a vid of the procedure.
    You have plastic laying around that you could do one or the other and show us? That would be great!
  7. #52
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by i58829
    I just noticed that , how old the post was but yea, I think you should start out with 220 or 320, try a really small area and see what happens.
  8. #53
    breastman569 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    Tucson & Mesa, Arizona
    272
    im not sure if anyone here knows about this or not but after your all done sanding your tank or whatever your working on go and get this new stuff by Turtle Wax called Ice! it is down right amazing its a plastic wax that wont leave the white crap behind and it is really amazing! it brings the color out like never before!
    1986 250R
    Ported Polished
    Paul Turner Head domed and milled
    Boyesen Rad Valve
    38mm carb
    Uni Air Box eliminator
    Full FMF Exhaust
    85 350X (getting there)
    86 250R (Roller/Parts Bike)
    85 Tri-Z (Parts Bike)
    85 NQ50 Spree (sick ass campus bike)
    Bikes Had
    85 200X (restored)(SOLD!)
    84 Z50R (SOLD!)
  9. #54
    rckstrgrl21 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    Carlsbad, Ca
    235
    Ok, I read the post, went out nd bought sand paper, and when I got back I realized i bought 60, 80, 200, grit. i strted with the 60 to get out deep scrtch that was on it, and realized it wasn't wet sandpaper.
    So to fix can I just start out with 220 wet sandpaper like nothing happened? or do I need to do something special now?
    My plastic was super super faded and i don't feel comfortable using a razor, so is using the 60 grit good to start with to get rid of the top layer?
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
  10. #55
    Dec 2006
    St. John's Newfoundland
    1,587
    I wouldnt use 60 grit. I would start at 220 grit. But I only polished wheels with 2000+ grit and I have never done plastic
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
  11. #56
    Nov 2007
    Carlsbad, Ca
    235
    At the store they had these sponge's that was covered in sand, that was like sand paper. are they for wet sanding?
    I think they would be easier to use, but i want to make sure they are wet sand compatable
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
  12. #57
    Dec 2006
    1,587
    There are ones I have that start at 220. They are like the size of a sheet of paper and about 3/8 inch thick white foam back. I am not sure if they are wet sandable but they work wetsanding. The black square sponge stlye ones about inch and a half thick are crap. Good luck.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
  13. #58
    saleen_n_around's Avatar
    saleen_n_around is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Clarksville, TN
    426
    Good info for sure....
  14. #59
    Terryville,CT
    1,616
    love this thread!!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
  15. #60
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    this should be made a sticky. very informative
