Results 1 to 15 of 22
Thread: I Hate Shaft Drive!!!
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    I hate shaft drive! Today my friend and I went up to a local parts and/or service place, TNT Cycles. We both own a 250SX He needed a new final drive for his, due to his teeth being beat to crap. So we went out back to the imfamous parts trike, and the guy there told us $100 for the final drive. While we were there I asked about a reverse machanism and such and he said 10 bucks. Well my friend didn't have the monies for the final drive so we told him we would be back for the stuff in a couple weeks.
    So we got back to my house, and we were riding for a bit. Well my SX has this problem where every-once-in-a-while when you shift gears it like doesn't "catch" and it also grinds. Well it did this to me toward the end of my ride comming up my hill. I didn't think much of it, it happens sometimes, although if I recall correctly it happened a couple times today. So my friend gets on it, and he rode it for a little, and when he was done, I guess it didn't want to go, then he driffed back a few feet, and then hit the throttle again, and it lugged like it was up against a brick wall and didn't go, and we were like, what the heck. So he shut it off and we started checkicng stuff out. Then we both noticed my output shaft assembly was in about 10 pieces, and we said "OH MY GOODNESS!!!"
    So we called TNT again and I talked to the guy and he said that you have to split the case to remove the output shaft because the gears are attached to it and such, and I'm thinking, man this isn't sounding good. He also said the reason why it would break is because either the bearings went out or a gear blew. I think the latter probably happened. So hes says to us, well, the cheapest route to go here instead of me selling you the output shaft assembly from the parts trike and charging you tons of labor to put it on is to just sell you and your friend the entire trike for $250 and since this engine was a smoker, put your top end and stuff on it and use that engine in your trike.
    Sounds like a good idea to me, plus I might end up with a working starter from the parts trike! And also when I'm done I could part out the rest. What do you guys think about this whole situation, the prices, and can you sell me stuff cheaper? This just hasn't been a good day for me. Somebody mowed off our mailbox too. Just needed to vent and get some advice. If these were chain drive, my friend and I might not have these two problems......
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    Sioux City, IA
    256
    I've got a 250es bottom end with a broken crank if you do want to buy the final drive. I got it over seven years ago that way and I think it sat for a few years before that. So it should be low hours. I know how you feel, I didn't want to go all the trouble of changing a crank and just put another engine in. Course i was 12 at the time. After the swap, I found out my new one was a smoker too and the kickstarter slipped. So I tried to fix the kicker and didn't know what was going on. It sat for all this time until I turned 20. Now its got an overhauled top end and all kinds of good stuff.
    "Trikes don't kill people. I kill people."
    www.250r.us
    Halifax, PA
    400
    Quote Originally Posted by BigRedRunner
    So your saying you'll sell the bottom end and final drive? How much for each?
    Sioux City, IA
    256
    I have no idea what its worth :?: . Its pretty much good for the gears and final drive, everything has been picked clean. The right side of the case and clutches are out because thats where the end of the crank let go. Some goof had 22" tires on it when it should have 25".
    www.250r.us
    Halifax, PA
    400
    Anyone else?
    Nothing to ride, I am sad. It's like family to me.
    Halifax, PA
    400
    Found out what's wrong with her today. It wasn't a bearing or tranny gear. What happened was the u joint broke on the front piece of the driveshaft, and when my friend hit the gas it just reved and then when he drifted back and he hit the gas again and it lugged down the shaft was jammed up and the weakest link gave, which sadly wasn't the clutch or more pieces of the driveshaft, but yes, the output shaft assembly. Who is to blame here: me, him, a ??%/??% split? Just give me your opinions. Also I have a question, I started it up today after i got half of the output shaft assembly off, litteraly broke in half, one gear came out with it, the other half is still attached to the engine and working. Anyway, why is that gear turning even when it's in neutral? Doesn't make any sense to me.
    If it was chain drive... in a similar problem, I would be buying a new chain, instead of a parts trike and replacing a bottom end. :x
    Instead of that parts trike should I buy a drive shaft and complete engine from this parted out SX on eBay: http://search.ebaymotors.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Febay motors%2Fws%2F&MfcISAPICommand=GetResult&query=250 sx&SortProperty=MetaEndSort&ebaytag1=ebayreg&categ ory0=6000&s_partnerid=2%26category2%3D10063%26site id%3D100&BasicSearch=&from=R2&catref=C3
    Rittman, Ohio
    6,276
    Ill just comment on your "if we had chains" comment. Over the lifespan of the vehicle your going to find that shaft drive mainetentance and repair is much, much, much, cheaper, and much more reliable than chain and sprockets. Yes, when they go, they are a royal pain, but this ATV would have likely been through 10 or 15 sets of chains and sprockets by now, and Ill bet its the first shaft drive problem, and most even last a lot longer.
    Halifax, PA
    400
    Quote Originally Posted by TimSr
    I guess your probably right, but I needed to gripe/put blame on something. But as you said, they are a huge pain when they go and to work on. Of course there's also the weight, still can't believe the shaft borke... It was so easy though to get the chain off the KLT, I don't even know how you disconect the driveshaft.
    Roanoke, VA
    4,038
    I had an '87 sx too. Never had a problem w/ it either. You should have seen some of the things it pulled and jumped over. I think its one of the toughest trikes Honda ever made. 8)
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Halifax, PA
    400
    Quote Originally Posted by ATC crazy
    Yeah I've pulled some beefy stuff with mine, there was always enough power! Although sometimes not enough traction.
    Foreman S huh? I like them, good pick.
    I would pay 250$ for a parts trike anyday. Add up what people are getting on EBAY for these items and you'll see thats a fair price.
    As far as the friend oweing you money for this. Did he ride as much as you and wear it out 50% of the time? Did he abuse it or damage it hitting something? Or did it just fail while he was on it? I would'nt lose a friend over it.
    Last word, I don't know about other automatics but my SX if it is in too high of a gear will bog and the gears will start smacking around. I don't believe it is a mechanical problem but just that too high of a gear and too much throttle don't mix. I immediately downshift when this happens. And when people ride it I tell them to make sure there in a low enough gear.
    Halifax, PA
    400
    Quote Originally Posted by Dirtcrasher
    The clucking/smacking/griding whatever seems to be random, doesnt matter what type of shift I make, just happens sometimes. Trust me, I'm not afraid to wind it out either. :-D
    Don't worry I'm not gonna put this on my friend after I thought about it and talked to people. But I do think he hit the gas harder than he should have when it wouldn't go, oh well.
    Hey, Just wanted to let you know I'm selling my 85 250SX for $750. Comes with extra parts and I'm located in western Pa.
    I wind my SX to the moon, power shift it and absolutely beat the living hell out of it. Other than the suspension it is bulletproof!
    Roanoke, VA
    4,038
    They are bulletproof. Between my brothers owning it and me, I'd bet my Foreman that there are close to 95,000 miles on the sx. My friend has it now and doesn't ride it as much as I did.
