i got a few questions...
1. how much does it cost?
2. is it worth it?
3. do i have to run diff gas?
4. can i do it my self?
5. do i got to rejet?
this is on an 85 200x with k&n clamp on filter and cora exhaust.
2. is it worth it?
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
1.it depends on who you get to do it
2.yes it is worth it if its done right and you have the right combination
3.you shouldnt have to run different gas,maybe just supreme gas
4.no you can not do it yourself
5.yes you will probley have to rejet
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
you can do it your self but i would not do it unless you do alot of reading about how to do it and you have a spare head because you can make it work worse then befor you started
If you want a REAL port job....send it out to someone who has done it a hundred times. You can (by yourself) clean it up to remove the casting marks. the larger ones with a grinder and smooth it out with sandpaper. Leave the Intake side slightly rough, and miror polish the exhaust side.
Sam from Florida
1985 BIGRED $ 200X
can i do it with a standard piston?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
yes you can do it with a standard piston,but you will notice even more power with a high compression piston though.
85 Honda 200X
88 Honda CR 125
