Results 1 to 12 of 12
Thread: banshee problems
    Dec 2003
    27
    Talking banshee problems
    I have a friend that has a 99 banshee and it will idle fine but just as soon as you give it any gas at all it boggs and shuts off. I don't know much about banshees so any help would be appriciated. It has FMF gold series pipes on it, port and polished heads, and k&n filter. I have checked the filter to make sure it is clean and recharged & changed plugs also. Please help!!
    If It's too fast your too old!!
    _____________________________________________
    '04 Rancher
    '85 Tri-Z DG Pipe, Boysen Reeds, Blackwaters (maybe for sale)
    '84 ATC 110
    '87 Fourtrax 250
    '96 Lakota 300
    Apr 2004
    Upstate NY
    102
    is the T.O.R.S. still hooked up on it? If so there is a good chance that is the problem.
    Dec 2003
    27
    Huh??? what is that????
    '04 Rancher
    '84 ATC 110
    '87 Fourtrax 250
    '96 Lakota 300
    Shrewsbury, West Virginia
    564
    If you didn't rejet the carb, that is your problem. When you add a pipe, K&N filter, and a true port and polish job, expect drastic jet size changes.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Dec 2003
    27
    Sorry I forgot to mention it had been running with all the mods for over a year. He decided to clean the carbs Lol "because it had never been done". I told him he shouldn't have touched it "if it ain't broke don't fix it". When he finished "cleaning the carbs" it run fine around his yard. He loaded up to go ride and when he got there it would start and idle but as soon as you give it gas it "coughs". Another friend of mine has it now and has it tore down to nothing going thru cerbs and checking what he can. Any suggestions??
    '04 Rancher
    '84 ATC 110
    '87 Fourtrax 250
    '96 Lakota 300
    564
    Ok, if it ran fine before the carbs were so called "cleaned" and it doesn't run right now, you can narrow it down to all of the fuel system. Make sure the carbs were put together correctly with the right settings, check for air leaks, make sure the carbs are calibrated in sync with each other, etc. BTW, I would think common sense would tell you that if the bike ran perfect with no carb problems at all, they don't need taken apart and cleaned. lol
    '82 Honda ATC 110
    Apr 2004
    Upstate NY
    102
    Throttle Override Switch =T.O.R.S the wires that come out of the throttle lever and the carb caps goto it and there should be a little black box that goes to it to, i belive the plug on the box is a 3 pin connector, unplug it and the ones to the throttle lever and the ones one the carb caps. If it still has all of this.
    Front royal, va
    2,186
    i bet he put the slides in backwards,the cut out on the slidesgoes towards the aircleaner!
    Jul 2003
    936
    Quote Originally Posted by 03 ORANGE SHEE
    wouldnt that hold it at full revs, it wouldnt idle it would be full throttle, of course i dont have a banshee so i could be wrong
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    Front royal, va
    2,186
    banshee slides are round,but at the back there is a cut out for air to flow through,and installing backwards makes them run like crap,i found out that years ago with my first one
    Dec 2003
    27
    How do you bypass the throttle overide switch? Does it give any performance gain? The carbs have been jetted to run with the mods above.
    '04 Rancher
    '84 ATC 110
    '87 Fourtrax 250
    '96 Lakota 300
    Front royal, va
    2,186
    all you do is unplug the black box to the left of the coil
