Results 1 to 2 of 2
Thread: What size valves come stock in a '80 185s vs. '83 200x?
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    I'm just trying figure if the 200x's have larger valves. Does anyone know if they are the same length as well?
    If they are larger, is there enough 'meat' on the seats to open them up?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    as far as I know you can just bolt them right in and you can use the 200x head as well.(look on ebay and you might find one of those heads that are ported)if you want power then go with the wiseco high compression piston kit.
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
