Results 1 to 7 of 7
Thread: how on earth do get the cam bushing off 200x??????????????
    Dec 2002
    salem, nh
    1,339
    So i'm TRYING to put my motor back together, and i'm slowly getting there, anyway..........i'm putting the cam back in and i noticed i'm supposed to have a dowel pin in the bushing on the end that lines up with a hole in the head. I dont remember ever seeing a bushing on there, and even if it is supposed to be there, isn't the bushing supposed to come off???? it just spins on the end of the cam and i cant get it off!!!! someone help please!!!
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Feb 2003
    Australia
    927
    I think at some stage the top end has run dry of oil and the bush has siezed on the cam. It has kept running and has worn grooves in the bush and cam and these grooves are holding the bush and cam together but still letting it spin. The bush should spin without wobbling side to side.
    Dec 2002
    salem, nh
    1,339
    crap! and if it wobbles a bit, or atleast i can rock it back a forth do i need a whole new cam or just a bushing? and how do i get the damn bushing off?
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by kilabeez0
    If the cam bushing won't come off and it wobbles then the bushing and the cam are junk. They will need replaced. The most common cause of this is a plugged oil port. This would cause the top end to starve for oil ( as greenhuman said ).
    Can you run it like that? You probably could for a short while. But I do not recommend running it. It may ( probably will ) cause you a lot more problems ( $$$ ) down the road if you do run it.
    Howdy
    Dec 2002
    salem, nh
    1,339
    any recommendations of cam? damn, now i wish i had bought an oversized high comp piston rather than a stock overbore :o
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Jul 2004
    Winnipeg, Manitoba
    50
    my 200m did the same thing...the oil port that shoots oil in the camshaft got plugged..not cool....the timing chain was rattling badly, so i had to check it out, sure enough, my cam was shot....the lobes were actulally pushed in about 5mm and this thing ran!!!..i would have never known if i keep running it...i have another 200es engine, so i stole the cam from it...a cam will probally run you about $300....my advise, tear the top end down, clean all the ports and galleries..and check out your oil pump while your at it..
    Sean
    1984 Honda 200ES
    1985 Honda 200M - Port and Polish
    Weisco 10.25:1
    197? Mini Chopper w/ briggs 6hp
    1985 Chevy 3/4 350 s/b, w/ 4bbl holley
    Dec 2002
    salem, nh
    1,339
    i have an entire different bottom end, and i had the cylinder bored .25 over and had the valve seals replaced and a valve job done so everything up top is clean. no way am i spending $300 on a cam for this thing!!! what a money pit!!!
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
