He means, you can mount the filter facing the front of the bike, and when you get up to speed, it will force air into it. Kinda like a hood scoop works on a car. I bet the jetting is a pain with that set up.
"I am going out of this world.....the same way I came in...screaming and covered in blood."
Hondatrikesrule thats not how i mount it, I still mount it right behind the carb. I dont mount it so air is forced in. Its not a huge pain but the main jet has to be increased big time. We ended up increasing the main jet to a 114 from the 100 that was in it. The next thing we are going with will be a 28mm flatslide carb soon.
3WheelsForever / Virgil
TrikeFest 03, 04, 05, 06, 07
1985 Honda ATC350X - TF2015 Project
YZ426 Hybrid Trike - On the back burner
so if i do that mod i should go to a 114 jet? where can i get the jet?
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
Well it may not exactly be a 114 jet in your area. Height above sea level can play a role in jetting. The higher you go the thinner the air, so that means you would add less fuel to the mixture.
use a D8EA, a DR8ES-L is the same thing as the D8EA but with a resistor, absolutely unnescessary on that bike, unless you're running digital garbage on there. The other plugs listed are not NGK plugs but are equivalent.Originally Posted by kilabeez0
The below sentence is TRUE.
The above sentence is FALSE
I just made a custom exhaust for my auto 200x and it is sweet!I gained alot of power of it too.i will post some pics tomorrow hopefully if i can remember.
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
I thought this post was to see other peoples 200X's??
it is i would like to see some other 200x's also lets see them i no a lot more people got them.... lets see that one with the cr125 motor and others
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
Got a new pipe!One of those amazing deals you find on ebay Buy it now $30.00 Brand new
whats the chain thing in the back(the tensioner or soemthign) also how do you like the pipe? and where did u get that parking brake block off?i need one cuz i got an avs clutch and i dont need the parking brake anymore. is that the one off ebay? and where did you get them ss brake lines?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
that is a very nicely done 200x, the 350x gear really makes it a looker. where did you come across the fork brace?
nice 3ww sticker on the carrier
I got the chain tensioner off of Ebay. It was originally for an 82 250r, but with a little work it can be made to fit a 200x. It was pretty much a necessity cause with the extra long chain it was kinda hard to get the tension right. the chain would be slapping the skid plate, or it would be too tight. Since I put the tensioner on I haven't had any problems. It works Great! The ss break line, fork brace and parking break block-off were also ebay buys.
That a very sweet 200X muddyNice job
86Honda250R
85Honda250R Sold
82Honda250R
Tiger 200 198? Sold
Tiger 250 198?
Tiger 80 (need engine) Sold
85 Tri-Z
86 Tecate
Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
