Results 1 to 9 of 9
Thread: 250es/sx Bigbore??
    Mar 2003
    Australia
    1,919
    250es/sx Bigbore??
    Gday,
    I know this topic has been gone over before but i never really got a straight answer.
    Does the old trx300es' jug bolt right upto the botom end of the es/sx motors? If so can the head be bolted right ontop of the trx300 jug? With this all being said and done would that make the cc's jump from 250cc to a healthy 300cc? Or would you have to swap out the crank aswell to make it a true 300?
    Would the trx jug be higher than the es/sx one? Or is it just fatter with more piston space?
    Would the crank fit right onto the crank shaft too? Im assuming the cam chain would need to be changed aswell to the trx300 one, am i right?
    Has anyone got any leads on a bigbore kit that were made back in the day? Im guessing the "bigbore" would just be like bolting up a trx300 jug?
    Do you think you would gain much power from this modification?
    Thanks in advance
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    I hear the 300ex will bolt up and the piston shoulds fit the rod
    the head for the 300 would have bigger valves, intake and exh may be bigger too
    Dec 2002
    SW Alabama
    764
    J&M atv supply sells a direct bolt on 300cc kit that fits 250sx,250es, and trx250.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Jason T's Avatar
    Jason T is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    UK
    341
    We are just about to attempt this conversion on our SX, I will keep you updated on progress!!!
    Jason T
    Mar 2003
    Australia
    1,919
    Thanks for all your replies. Do you know how much tose kits are going for whiteman?
    Matt
    Newfoundland
    5,280
    doesnt the trx 300 2wd motor just bolt in, not sure if the mounts would need modification. just read that it fits over on .org
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    nononononono!!! First things first!!! You use the trx300 2wd or 4wd UTILITY quad jug and piston/rings. This modification brings it up to 282cc. You keep the 250sx head and valves and what not because of the more aggressive rocker arm design. I don't know if the 300 motor bolts in, i have checked and i am pretty sure it doesn't but i wouldn't do it if it did because i beleive the 250sx features a higher geared transmission. This mod will absolutely NOT make your bike go faster; it will give you more power to get to your top speed faster, and make you wheelie easier. It can make you go faster however, if you magically change the pinion size inside the differential, or if you plan to run the motor at 13,000 rpm's.
    The below sentence is TRUE.
    The above sentence is FALSE
    Jun 2003
    stockton nsw
    85
    does the sx head mount up to the trx cylender but thne onto a 250es.... :P
    1982 Suzuki Sierra 1L - Nissan MQ axles and 38" TSL Swampers
    1982 LWB SIII Stage one Land Rover Tray Back- 4BD1 Isuzu powah!
    Mar 2003
    Australia
    1,919
    Im pretty sure the trx head will bolt right up form what ive heard. Will it make much of a diffrence with anm sx cam and that jug on it? Anyone got a good sx cam they will sell to me here in aus?
    Thanks,
    Matt
