Results 1 to 3 of 3
Thread: air cooled snowmobile motor in a atc
    Apr 2004
    california
    has anyone installed a air cooled snowmobile motor in a atc? i ride dunes only, do they get too hot, would i be better off with a liquid cooled?
    thanks jon
    Jul 2004
    Winnipeg, Manitoba
    50
    Air cooled...very, very bad idea....During the winter, u can almost burn those engines up if its to hot, say like couple degrees over zero celcuis, they will seize upp..its happened to my buddy 440 sport skidoo...a liquid is different, u will need a cooling fan setup, as a snowmobile cools the "raditator" with snow in the tunnel under the seat....but its definatley possible with a liquid cooled motor
    1984 Honda 200ES
    1985 Honda 200M - Port and Polish
    Weisco 10.25:1
    197? Mini Chopper w/ briggs 6hp
    1985 Chevy 3/4 350 s/b, w/ 4bbl holley
    Nov 2002
    1,189
    I've seen several aircooleds sieze in hot weather. I've seen all types in go karts. The ones with the fans on the motor, that run off the belt, (forced air) tend to last a little longer than the regular type that needs wind. However, both types tend to sieze up, especially if the weather is hot, or you run a lean mixture. The liquid cooled get hot too, but not so hot that they sieze. Most people run a large fan in back of it. (Like the one on a car) Liquid cooled would be your best bet, especially if you run in hot weather, and the air flow to the motor is limited.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
