Hey, i am having the same sort of problem with the tri z that i had before. When I give it gas it revs high but it barely moves, it will sometimes not even make it up a little tiny hill and I have to pull the clutch in and gas it to try it again. It does this in every gear. I gas it and it revs high but with no power and the bike barely moves but when I let go of the gas and give it only a little bit it will run like normal unless I gas it again. What could this problem be from? I had the top of the engine off and a mechanic friend of mine said the top end was good. I am getting the stock sized jet for the carb tomorrow, could that be the problem, the jet too big or too small? Any other ideas? appreciate it very much, Rob.
