I took the aftermarket jeeting out of my 110, and put a stock jet in. I then took off the performance pipe, and put on a stock exhaust. I let the airbox off with a clamp-on filter. My troubles before were it was running rich and fouling plugs like crazy. With the stock exhaust and the clamp-on filter, I pulled the plug, and it was white. I think if I turned the air flow down some, it would richen up a bit. Where is the air screw on a 85 110 carb.? And to lessen the air, do I turn it left or right? thanx
