Results 1 to 15 of 16
Thread: tubes or not, that is the question
    Jun 2004
    geraldton, west australia
    1,068
    hay guys just a little opionion poll...
    tubes
    or
    tubeless
    and why....
    Dec 2002
    deer park, texas
    2,336
    well i like to run tubless on new tires just because after buying new tires i dont want to buy tubes too. if the tires are bad i will tube them but that is it.
    Mar 2003
    Australia
    1,919
    Tubeless is the only way to go in hilly country. As for flat country you can run a tube......
    Thats my 0.2
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Jun 2004
    1,068
    what about dunes and trail riding
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    I have been trail riding on hard clay, sand, and rock with tubes in the rear of my old SX and had no trouble at all. Even with new tires. If they will hold air I leave them alone, but if they leak around the bead/edge of wheel slowly I usually tube it to avoid the annoyance. I rode the SX hard and made many a jump with tubes, and never had a problem.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    i had to resort to running tubes on a set of turf tamers on my old 84R when one popped and wouldnt patch for nothing,, got the tubes in, worked well on the roads and fields, but when i went up hills and rough stuff the tires spun on the rims.
    Mar 2004
    1,727
    I didnt have that problem in the hills and mountains of north Georgia with my tubes. I take that back. I did have that happen on one rear wheel when I first got it. However the guy I bought the trike from had put a 9 inch tube on a 8 inch rim. Tire shop said that wasnt wise. Not to say that it could not happen with a 8inch rim. Its probbably more likely with a real weathered tire. Rubber is not as supple and doesnt stick to the wheel as good. Interesting point. Never thought much about it. Makes sense though.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Howdy's Avatar
    Celina, Ohio
    10,079
    I run tubes in most all my tires. I do this so I don't have to worry about knocking the beads off the rim. A very good example is our Wrecker ( 88 TRX125 ). I will have to get a picture of the one tire. Maybe tomorrow.
    Howdy
    If I have a leak then I will put a tube in them and I take my trikes in all kinds of different terrain and they haven't busted so I would say tubeless if the tires are new but if they leak then I would put a tube in them.
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Rittman, Ohio
    6,276
    If your rims are in good shape, and your tire bead is in good shape, Id advise running tubeless. Its a lot easier to plug a tire and to patch a tube. You also wont rip the valve stem off if it turns on teh rim, which is commonplace on the 250 two strokes. If you have a rusty rim, one with a bad sealing surface, and sometimes split rims can be a pain to make leak free, or if your tire has a bad bead, or a hole that doesnt plug well like a split of a slice, then run a tube. If you run tires in the condition of the tires Howdy has on the wrecker, run two tubes, and put tire chains on it!
    Jun 2004
    1,068
    well my tires are brand new and i have split rime...i dont think there is much rust on the inside of my rims.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by TimSr
    What are you trying to say here TimSr? Are you saying the wrecker tires are old, worn out, or both?? lmao It funny the wrecker goes where other machines don't. Sometimes with a rider and sometimes without. It's nice having a machine that you don't have to worry about hurting. In fact we have tried to kill it a few times ( we check the oil when it quits smoking ). But it just keeps going and going and going. This might have something to do with the energizer batteries we use in it. lol j/k What can I say? It's a Honda, built to last. The best never rest!!
    Anyone that has ever rode the wrecker knows it is a very unique machine. And if your into mud it will really satisfy your thirst. Actually this thing is in great shape for a 1988. I bet you can't find any cracks in the fenders. lmfao j/k
    Back to the subject of tubes and why I use them. If I didn't tube the tires this machine would need to be fixed before riding. But since I tubed the tires it's good to go.
    FYI, The bead was on the rim when we took it to TF04. By the time TF was over the bead had started to come off the rim ( about 2-3" ). We kept riding it without doing any repairs ( never even added any air ) and it now looks like this below.
    Like I said above. You can't kill it!! For reference I took one picture of the other side front tire.
    Howdy
    Cincinnati, OH
    3,289
    my god why dont you just shoot that poor thing and let it it die !
    and is that tires bead broke and thats thats just the tube holding it on?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Xowner
    1st off, it's hard to kill a Honda ( The wrecker is proof of that ).
    Yes, the tube is the only thing holding the tire on. The wires in the bead broke and that allowed the bead to come off the rim. The inside bead is being pushed on the rim by the tube. I am sure if I let the air out of the tube I can remove tire with No other tools. This is proof that Tubes are a good thing. lmao
    Howdy
    Mar 2003
    Barnesville,Ohio
    2,298
    that thing is a beast Howdy...the only thing i run tubes in is dirtbikes and bicycles
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
