Results 1 to 12 of 12
Thread: xr200 bottom end in 200x?
    Oswego, IL
    1,858
    ok if i put a xr200 bottom end what will i gain? also if i put an xr200 cam into my 200x will that make a difference?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Mar 2003
    Barnesville,Ohio
    2,298
    probably nothing...i would say it they are both 1:1
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Dec 2002
    749
    The cam is supposed to help top end alot. The bottom end you would gain a 6 speed instead of 5. The six speed would "close the gap between the gears and increase the spread between first and sixth, providing a gear for everything from tight trails to flat out screaming"(quote from an article from 3 and 4 wheel action).
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    Oswego, IL
    1,858
    can i just drop in an xr200 cam?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Apr 2003
    Spanaway, WA
    1,248
    the atc motor is derived from the XR so yeah
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    a xr 200 carb will give you more power too
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Oswego, IL
    1,858
    ya the carb will but i can get a brand new cam for 74 bucks (the stock one that is)]
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Washingtons Crossing, Pa.
    2,977
    .... won't the kicker be reversed on that XR's lowerend?.
    yes if you use the xr bottom end then the kick will be backwards but you can use the 200x gears to correct the problem.
    85 Honda 200X
    88 Honda CR 125
    Mar 2003
    Barnesville,Ohio
    2,298
    yea, that and you will need to use the left sidecase too
    1984 Honda 200ES
    wouldn't it be easier to buy a complete xr 200 engine and put it in?
    85 Honda 200X
    88 Honda CR 125
    Mar 2003
    Barnesville,Ohio
    2,298
    yes...but it will be cheaper to just get the bottom end
    1984 Honda 200ES
