Thread: 400 Honda
    350Xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Huntington, W.V.
    320
    400 Honda
    I have a 400 honda foreman and it backfires loud as hell all the time and seems to run a little rich, every one of these bikes i have seen does this. Anyone here have one of these that does this? thanks
    ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
    If something is backfiring, its your carb that is the culprit.
    My Buddy has the 350 version and it backfires, sputters at times and what not..........but I just figured: hey its old and its a Honda.....its not expected to run.
    However, I know about 4 People with 450es/s''s are none of them have backfiring problems......that appears to be a Honda problem that comes with age and isnt expected always.
    Maybe Honda needs to be mroe choosy with its jetting specs of choice of Carb manufactuer?
    Good luck,
    Rob
    Roanoke, VA
    4,038
    Easy on the Honda's ATCRYDER I think its just a jetting problem. My sx backfired continually the first week I owned it and a jetting change solved the problem. You even said it ran a little rich, thats probably why although im not sure. :?
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    A dirty airfilter can cause a rich condition, might be a good idea to clean/change it. If not I would clean the carb out, reset it to stock settings, and if it still backfires, then play with the jets.
    85 200x - Torn apart
