Results 1 to 15 of 18
Thread: How do you patch cracked fenders?
    Jul 2004
    Here
    126
    I am in the process of cleaning up this little 70 and the rear fender is cracked all over. There is a chunk missing off one corner but I plan to smooth it and remove the same amount from the other corner to even it up. So far I used some adhesive to align the cracks abd put a 1/16" - 1/8" groove into the crack line on the top side. I am thinking either use fiberglass to fill and sand, or possibly melting some plastic into the grooves. I will do the underside this way as well. Any recommendations...besides just replace it ? Thanks
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    You can always drill small holes and use zip ties.
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    almac16 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Halifax, Nova Scotia, Canada
    226
    Quote Originally Posted by aaakowalski
    ..........the classic stitched look
    I used wire instead of zip ties. Worked well.
    Plastic welding is an option if you have one. Although my bike was plastic welded and it broke so I stitched it up.
    Jul 2003
    5
    I know it aint pretty but I literaly pieced together my 250sx fenders with a heat gun and putty knife. When done it looked pretty cool, it looked like it had scars. the SX was soon after nick named frankenstien.
    petethekiller
    Jul 2004
    Here
    126
    I was hoping for a more original look.
    I was gonna stick the pieces together and then primer it and paint but I have a couple spots that are in what I would call stress areas and they just continue to crack. I used fiberglass jelly and it wouldn't stick, I did mix some left over plastic dust from sanding with super glue and it dried on super quick but I am not sure how long it'll hold, the one stressed area seems to wanna keep cracking. I may have found a replacement so that would be even better. If that doesn't work out then I might invest in a plastic welder kit but I am kinda hesitant since that doesn't seem to last long either.
    Appreciate the responses
    Jul 2004
    Mud hill. close to water !
    3,658
    crazy carpets and rivets with washers.
    red crazy carpets match the honda red real well !!!
    and they are tough !
    Jul 2004
    Here
    126
    bigredhead
    Whats "crazy carpets"?
    Jul 2004
    3,658
    you don't know what they are??????????
    do you have snowy winters?
    they are sheets of thick plastic with 2 holes for your hands to fit into, kids use them to slide down snow hills with.
    snow sliders.
    Jan 2004
    226
    Quote Originally Posted by bigredhead
    snow sliders.
    Hmmmm bigredhead.....maybe that's a Canadian thing
    Jul 2004
    3,658
    haha.. sure is !!
    check walmart, kids toys, any thick tough plastic, place a piece underneath your current fender and rivet it on !!!
    not pretty, but sure keeps you clean !
    Hampton, Virginia, C.S.A.
    2,664
    JB weld fools lol just messing with yall but use jb weld
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Indiana
    458
    uhh, just buy some new plastic.
    Current rides:
    85 Honda 200x -- For Sale
    86 Honda 200x
    79 Honda Z50 minibike
    If speed kills......I'm a dead man!
    Jul 2004
    Here
    126
    snow sliders.
    Haha..actually we call them sleds here. Never heard of them being called "crazy carpets".
    Actually most of the fender is there, well most of it, but there are cracks all over, suprisingly enough there are minimal scratches. I get what your saying now... thanks for the suggestion
    That crossed my mind, but I wasn't sure if the flexible plastic vs. the hard jb weld would just cause future cracking. Is this something you've done and it lasted a while or is it crack prone? thanks
    Mar 2003
    Barnesville,Ohio
    2,298
    them crazy carpets are awesome....i went thru quite a few of them when i was a little kid. they were a pain in the ass sometimes cause you had to unroll it all the time
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    NE. Ohio
    484
    This might be what your looking for. I havnt used it or know anyone who has. But I think It would be worth a try.plastiweld
