will a 200x/350x front end fit on a 84 200s.. i want to make the change
yes i 200x front end would fit and so would a 350x front end but since the 350x has a higher stance to it then it would make the 200s a chopper so i would go with the 200x front end.All that has to be done is the steering stop has to be cut off and re-welded on in the oppsite way...
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
if you can get ahold of a good 350x front end ill give u my 200x front end if that helps any. im tryin to do up my 200x with 350x shocks so it will work out both ways
