Results 1 to 12 of 12
Thread: welding z clutch side cover?
    Jan 2004
    UK DEVON
    101
    hi there
    i have cracked my tri z clutch side cover n was wondering if it will hold up if i get it welded?
    has anyone done this befor?
    cheers
    nipps
    Rides:
    86 Tri z phase 1 wrench report porting n DG pipe (this beast is what really got me into trikes!!)
    84 honda 200 big red
    84 yamaha 225dx
    "To scrout or be scrouted the question remains!!?"
    Shrewsbury, West Virginia
    564
    Welding aluminum takes a special welder and a lot of experience. They make a kind of rod now where you just heat it up with a propane torch and it will "weld" aluminum. I would try that or JB Weld.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Jan 2004
    UK DEVON
    101
    bj weld just cracks off instantly when i try to kick start it!!
    has any one here had it welded?
    nipps
    Rides:
    84 yamaha 225dx
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    It is not a problem to weld Aluminum "IF" you have the right gear.
    By messing around with JB etc. you are makeing it worse for the welder when you finally have to take it to him. Aluminum has to be very clean so the more junk you put on the more work it is to clean it up.
    mart is offline *CERTIFIED* Mad Scientist Arm chair racerAt the back of the pack
    Apr 2003
    newcastle australia
    271
    brook is right,aluminium has to be very clean trailprotrailpro u can even think of welding it.i would prob suggest tig welding it.And the other thing is you will have to find out if yamaha used magnesium in there castings because if they did dont even worry bout it u wont b able to weld it.hope this helps.
    wolfspider's Avatar
    wolfspider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    HARROGATE, ENGLAND
    376
    tri z
    hi nipper
    theres a breakers near me with a tri z in, he might have a clutch case for you, if you want the number either pm me or email. its in south yorkshire, so you`ll probably need to get it delivered.
    steve.
    HONDA ATC250ESJ 1988
    HONDA 250R `85 restored SOLD
    HONDA ATC 350X `86 restored SOLD
    HONDA ATC 250ES `87 SOLD
    YAMAHA YZ100 `80 project
    HONDA ATC350X `85 PROJECT FINISHED
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    I had mine welded and it did not work because of were the crack was positioned. The weld hit the kick start gear.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Nipper could you post a picture of your break or describe it some? I've been working on a broken 250R case for about the past 4 days trying my best to patch it up. I'm using a Miller Dialarc TIG welder. I've been welding on aluminum for a while now and I'm not an expert but I'm better then a dobber. Aluminum indeed does have to be very clean before you weld on it. I've had the best luck using an airpowered sander with 40 grit on it and just going over the surface real well.
    Rittman, Ohio
    6,276
    These cases are known for cracking becaue of the stress of the kickstarter. They can be welded by someone who is good at it, and it doe take a special talent and equipment to weld these. I had one welded that was stronger than the original, and lasted for years, but whether or not they can be welded, and how well it will hold mostly depends on the location and condition of the crack. JB weld will not work at all because this is a high stress area, However, (on a good one) a coating of LB weld on the entire lip under where the kickstarter bolts on, to eliminiate the space below it, will give it a lot more strength and eliminate the bend point, allowing a new one to last much longer.
    Watertown, New York 13601
    3,382
    Mine cracked and i bought a new one from yamaha for $100.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Live Oak, FL
    15,069
    Do you guys with your broken cases still have them? PM me if you do.
    use a stainless steel brush to clean aluminum, it leaves no residue. Anything else will leave you with clean looking metal that still oxidizes when welded.
    Banshee Killer
