Ok guys maybe this post will help someone else besides me. My 87 Big Reds electric start acts up from time to time. This is what it does. You walk up and get on, turn the key on. The green Neutral light lights up. You hit the starter button and you get a click and the neutral light goes out. Then nothing, no clicks, nothing. Ok so heres my solution and maybe someone can tell me the problem. So it wont do anything. Neutral lights out, regardless if you turn it off and back on. It will not light up again until you kickstart it. So. I hook a hot wire up to the positive terminal on the battery and touch it to the small yellow wire at the solenoid. The postive side. Not the green, and not the big red or big black wire on the top post. The very small yellow wire. if you have the key in the on position, as soon as it makes contact the trike will turn over and fire off. If the key is in the off position, It will just turn the starter and engine over until you pull the fabricated hot wire loose. Ok. This is where it gets weird. Once you do this and you have killed the engine, it will crank normally for quite a while. It did this 4 months ago and hasnt doen is since. This was until last week. Now today it did it again. Im thinking the keyed ignition is working intermitten. What do you think. I have a entire parts bike with good electical parts. I have tried to change the switch, but it had no affect until I put that hot wire to the solenoid. Could that yellow wire have a short in it? What do you think. Its liveable as is, but a little agrivating. I just left the hot wire insulated and hooked up. I taped it to a good spot on the frame incase i needed it. What do you think? John?
ClayW
