Results 1 to 11 of 11
Thread: recommend a good rust remover
    Jul 2004
    Here
    126
    This little honda 70's tank has rust all over the exterior. Its pretty bad IMO, I was gonna just sand it off but thats not gonna cut it. If someone can recommend a rust remover that actually works and doesn't break the bank, that would be great. Thanks
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    good old sad papper :P thts all i can think of
    Houston,Texas
    1,044
    For heavily rusted pitted parts, I like to use a wire wheel on a gringer, or sandblast the part.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Naval Jelly works good also. It a liquidy paste. Turns rust black and disolves it
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Jun 2004
    Brazil, Indiana
    1,389
    use some good old sand paper or some steel wool...if that dont work...geta belt sander...they always work unless its got some dents
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Mar 2003
    Kansas
    1,507
    There is some stuff called Rust Converter. You can get it at any napa store. You just use a brush, put it on, and it does the work for you. It turns black, and turns into primer. I would then sand it really good, and still try to get off as much as you can.
    brandosfiero's Avatar
    brandosfiero is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    west unity ohio
    199
    hi well if it was just surface rust you could use works the kind in blue bottle.this what i use on old rusy chains and let them sit in works for a day or so.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    We have some stuff down here at alot of people use called Ospho. It makes a chemical reaction that litterally makes the rust curl right off the surface. Very good stuff, comes in one gallon plastic jugs and costs about $40 I think
    Jul 2004
    Here
    126
    I wish it was just surface rust...would make this a lot easier.
    Maybe I can get my hands on something that works around here..after I looked a little harder most of the products contain the same acids so with luck I will get a brand that doesn't dilute the crap out of it. That Ospho sounds like something worth finding. Thanks for the replies
    Oswego, IL
    1,858
    good luck, i would just get some wire brushes and a good drill and go to town lol
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Jul 2004
    Here
    126
    I will try and remove the deep stuff with a die grinder I have. My problem is patience and this sucker will heat and warp metal in no time flat, figured that out on my truck. Given the many dents already in the tank it wouldn't be that much of a loss. I tried to grind some of the rust off with a stone and it took forever to reach rustless metal...I need the converter for added assurance the filler and paint don't bubble. Only time will tell I suppose..thanks for the reply
