Frankensteined
I will be so glad when I pay off my credit card so I can restore my 200x just got a 85 frame and some motor parts the clutch cable on the 84 was about a whole bike length longer than the trike fortunately the parts bike had a cable on it ,on the 84 the clutch arm had a hole drilled through it and a spring attached to it and the frame, the cable holder was about 3 inches back from where it was supposed to be no cluthch adj.what soever exept at the perch .Fixed back to original set up 1finger pull clutch no more spring . went riding the other day trike quit running ,kicked it fired and quit would not run ,pulled off carb lo and behold Frankenstein again
wood srews for bowl screws ,gaskett sealer (permatex blue) for a gasket ,jet clogged up with gasket sealer ,Will get another brand new OEM carb for $150.00 why do people frankenstein bikes ??? In the end it costs more If ya cant do it right dont do it at all .Who is it here that has a little saying "striving for perfection.........."?
83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
