DOES THE 250SX AND THE 250EX BIG RED SHARE THE SAME PARTS? DO THEY INTERCHANGE?THANK YOU, MOZONE22
FENDERS FRONT FORKS FRAME?![]()
the forks are different, fender may be the same, and I dont know about the fram, but it must have some differences, it sits lower. The front forks are like the 185s forks, they are curved, the 250SX's are straight.
RIDES:
Current OG rides:
~1993 300EX 1 owner (just sold)
~1993 TRX90 matches the 300
~1996 Z50R the FIDDY
~1992 YSR50 (sold)
~ATC 70 (w/suspension), ATC 185S (w/susp), 250SX, 350X, etc, etc, ALL SOLD!
WTB: small machines - ATC70s w/ suspension, TRX90, z50, CRF/XR70/110, CT70, CT90, SL70 etc.
Favorite riding spots:
1. Twin Buttes, San Angelo TX
2. Turkey Bay, LBL KY & Linton Beach in Bumpus Mills
3. Sunnyside ATV, Wrens GA
I believe the motors have the same mounts, however, the frames are quite different, because the swingarms are really different, and don't interchange, because of really different mounts
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
Not sure about the frame, but the fenders (front and rear) wont interchange.
Notice on the ES that the rear fenders are hinged...
the engines will interchange and I have been told that the rear ends will too,the frame'swill not as far as I know and the fenders will not.
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
Thanks Mozone22!!!!!!!!!!!!!!
