Results 1 to 15 of 25
Thread: white smoke is caused by ?
    jmsmilin's Avatar
    jmsmilin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Yammie 225 DX running but smoking, any thoughts? What would cause it?
    RIDES:
    Current OG rides:
    ~1993 300EX 1 owner (just sold)
    ~1993 TRX90 matches the 300
    ~1996 Z50R the FIDDY
    ~1992 YSR50 (sold)
    ~ATC 70 (w/suspension), ATC 185S (w/susp), 250SX, 350X, etc, etc, ALL SOLD!
    WTB: small machines - ATC70s w/ suspension, TRX90, z50, CRF/XR70/110, CT70, CT90, SL70 etc.
    Favorite riding spots:
    1. Twin Buttes, San Angelo TX
    2. Turkey Bay, LBL KY & Linton Beach in Bumpus Mills
    3. Sunnyside ATV, Wrens GA
    Oswego, IL
    1,858
    piston rings? to much oil? to ritch?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    what does ths spark plug look like?what kind of oil are you running?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Apr 2003
    Spanaway, WA
    1,240
    if it was rings it would be oil smoke meaning blue smoke wouldnt it i think you're probly running too rich a fuel mixture. smokinp a 225dx is a fourstoke.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Jun 2004
    Brazil, Indiana
    1,389
    or u may have some water in the engine...ive had that before
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    I know...what does this have to do with it?I am not talking about the oil to gas mix ratio I am talking about the oil that he runs in it.the oil might be to thick causing smoke.
    85 Honda 200X
    88 Honda CR 125
    jmsmilin's Avatar
    hmm, smoke looks white, so thats why I didnt think it was a piston, could it be something with the valves?
    RIDES:
    Current OG rides:
    ~1992 YSR50 (sold)
    Oswego, IL
    1,858
    it coudl be i dont think it is but you never no. i would make sure your not running to ritch/lean. check you plug
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Apr 2003
    Spanaway, WA
    1,240
    Quote Originally Posted by smokinp
    i'd like to hear an explination on why that would cause white smoke.
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    jmsmiling. More info please. Smoking when cold and not hot, smoking only a startup, smoking all the time...??? Is it using oil?
    White smoke will be oil burning. Sometimes oil buring will have a blue tint to it but make no mistake about it. It is oil. If it were running rich as someone mentioned it would be "Black" smoke, not white for sure.
    Give us more info and we can diagnose the problem a lot better.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    jmsmilin's Avatar
    well I havent done any work on it or looked into it. Its a trike for sale cheap, but it runs and is smoking and Im considering it if the price is right. But Im not to keen on changing the piston as I have several other projects going on.
    RIDES:
    Current OG rides:
    ~1992 YSR50 (sold)
    Running oil that is not suppose to be used in a trike(or any machine)will cause it to smoke more then its suppose,like running oil that is too thick is too much oil and this makes burn off(smoke).my friend used oil that was too thick by mistake and his trike smoked really bad.
    85 Honda 200X
    88 Honda CR 125
    350xsx's Avatar
    350xsx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2004
    Tinton Falls NJ
    348
    valves or anything withoil burnin with the gas is usually blue smoke, unless you overfilled it with oil, than it comes out white, other than that im not sure why it would be white
    Jul 2004
    Winnipeg, Manitoba
    50
    About 3 years ago...whenever i did an oil change on my 200m, it would blow white smoke after the change...it never smoked trailprotrailpro the change..only when i changed oil..it would smoke white when it was cold..what caused this??
    1984 Honda 200ES
    1985 Honda 200M - Port and Polish
    Weisco 10.25:1
    197? Mini Chopper w/ briggs 6hp
    1985 Chevy 3/4 350 s/b, w/ 4bbl holley
    jmsmilin's Avatar
    now my friend has an ATC90 blowing a little white smoke?
    RIDES:
    Current OG rides:
    ~1992 YSR50 (sold)
