Results 1 to 11 of 11
Thread: 83' 200x oil...what r u guys using????
    Aug 2004
    Blackwell, Oklahoma
    124
    i was wondering what kind of oil u guys r using in trailprotrailpro 200x's...mine is a 83' 200x
    10W30 quaker state peak performance
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    I'm using Amsoil in my 350X.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    10w-40 Mobil. Anything that is "NOT" energy conserving should be fine.
    1985 200X
    I run amsoil in my 83 200x, trx 250, klt110. My machines see a lot of use year round. So far so good with the oil I have chosen.
    83 200x, 85 trx250 fourtrax, 85 klt110
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    The guy at the honda shop told me that car oil is too fine for atv's motorcycles
    Due to the wet clutch, it needs a bit more grit in it for the clutch to grab well, he said it also does damage to the head, however I've always run car oil, just regular castrol gtx, lately i've been running syntec, I bought some castrol 4stroke motorcycle oil, and plan on switching over, but I also heard once you start using synthetic, it's bad to switch back. The only reason why I semi-believe the guy is because I noticed my clutch seemed to be slipping a bit
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    leprogle's Avatar
    Mar 2003
    New Brunswick
    345
    Oh, and a clutch ques. for the clutch gurus:
    When i turn off my bike, it does a whirring sound, and like something still spinning, and then a KA-Chunk. My friend said it is the one-way clutch bearing. Is that what would do that? could it be worn out, or not advanced enough?
    any knowledgeable suggestions appreciated
    Caution
    my 200 does that too....
    85 Honda 200X
    88 Honda CR 125
    Moncton Newbrunswick,Canada
    509
    my 110 did that..
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Quote Originally Posted by leprogle
    My owner's manaul says to run 10W-40...but I can't remember the specific letter designations it asks for. Our ATC manuals were written back before the companies figured out they could rebrand oil as "motorcycle oil" and sell it for 4-5 times the cost of a quart of regular oil.
    1985 200X
    Aug 2004
    Blackwell, Oklahoma
    124
    i'm gunna try Mobil 10W-40...it seems like a good choice.....
