I NEEd to know what the valve clearance is supposed to be on a 250SX as soon as possible, its way wrong on mine, so someone please help me!?!
it's .08mm or .003 inch on both intake + exhaust.
john
thanks a lot but how are you supposed to check it again?you adjust it with that nut on the top right?i have the feelr gauge and stuff already
yes ,,, the adjusting nut on top of the valve stem.
but first you hafta have the motor at top dead center of the compression stroke.
on the right side of the side case you have 2 removable caps ,,, take both out.
using the nut on the crank shaft ( biggest hole ) you will be able to rotate the motor CLOCKWISE untill you are able to line up the "T" marking on the rotor.
( there is another marking next to it so be sure to get the right one - T )
normally if you have the T mark lined up and are at T.D.C. on the compression stroke ,,, you will be able to wiggle both valves a little. if one is tight , you will need to rotate the engine 360 degree.
adjust away.
it's kinda rough to do with flat feeler gauges and still a challenge to do with the set i bought that has the curved ends on them. but doable with a little effort.
i also want to add that it is highly advisable to make sure the timing is corect before adjusting the valves and that the valve adjustment is done with the motor cooled down.
good luck ,,,, john
thanks a lot, yea i ones with the curved ends thanks again
kyle
o yea but were do you put in the gauge, inbetween the nut and the valve stem?Thanks
between the adjuster stem and the top of the valve/sping thing
Be careful man. Could cost your self some big dough.
ClayW
Clay Whitman
Newnan, GA
AMSOIL DEALER
My Toys
2008 Yamaha Rhino 700 SE
