Thread: Front Wheel Removal 200es Stuck!?
    Minnesota
    790
    I was going to take my front hub assembly off today to get my leaky tire tubed at a local shop. I've got both rear ones tubed and they have held up great and never leaked. For some reason the tires I'm running want to leak all around the sidewall. Can't patch and I don't know if i want to use slime...
    Anyways your supposed to just unbolt one end of the axel and it should slip right out the other side right? The axle will not budge at all and I've hit it with a repeatedly and soaked with PB blaster. Am I missing something? Any tips?
    Thanks in advance for any help.
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    Mar 2003
    Australia
    1,919
    I had the same problem on my 200es and my 250es. It is just a common problem that will be encountered. Try heating the fork leg up a bit and soaking it in some diesel or other penetrant for a few days then heat it up again and pound it out. If all else fails take it to a engineer and get it pressed out. If you do get it out, break out the old grease tub and lube her up before putting it back in. Goodluck Nick,
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Minnesota
    790
    Thanks matt. I'll bust out the torch tommorow.
    -84 200es Big Red
    Long Island NY
    135
    my axle on my old 200s had a bolt on the end that kept it from moving but once you took that off the axle had to be unscrewed ...... there were treads in the fork .....
    Jun 2004
    Brazil, Indiana
    1,389
    yes my 185s was spose to be unscrewed but the retard who had it before me striped it all...unbolt the tire off the hub and take it off first...then try unscrewing the rest it works easier than trying to or pull..if that doesnt work do wat atcmatt said
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
