Results 1 to 9 of 9
Thread: Problem with Tecate motor winding out
    Apr 2003
    Central New York
    1,864
    I had the Tecate motor rebuilt and trailprotrailpro it would wind out no matter what we did to the carb. We figured it was sucking air from somewhere. I got it back in and its doing it again. The carb is rebuilt and Im wondering if its the carb or maybe the CDI box? Any help would be appreciated. I've waited 8 years and I was hoping to ride it tonight for the 1st time. Now I have to suffer longer.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Maine
    466
    so when you start it up it is reving right up without giving it any throttle????Check to see if you have any free play in your throttle cable and see how much clearance you have between the throat slide and barrel of the carb.
    1987 200x
    1987 Big Red
    1986 250R
    1986 Tecate
    1986 Tri-Z 250
    1986 Big Red
    1985 Polaris Scrambler
    1985 KLT 160
    1985 Tiger 250
    1985 Big Red
    1985 Big Red
    1985 250sx
    1985 70
    1985 225 DX
    1982 185s
    1983 110{Red}
    1983 110{Blue}
    (2) 1977 ATC 90
    1971 US90 Red
    1971 US90 Parrot Green
    1971 US90 Blue
    cedar falls, IA
    546
    Ive had air leaks where the carb boot meets the cylinder. If you have recently had the motor rebuilt this would be the first place I would look.
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
    Apr 2003
    Central New York
    1,864
    Hmm
    Only two ideas. Thanks guys for your help. I guess no one else can help. You would think someone would want to solve the mystery
    84-85 Custom Tecate
    Apr 2003
    Central New York
    1,864
    Ok
    Ok I adjusted and re routed the throttle cable. I got some throttle response and it didnt run wide open for a second. I gave it a twist and it acts like the throttle sticks even though it wasnt stuck. Now the GOOD PART, It started winding out so I hit the kill switch, it didnt work so I yanked the Plug Cap. I kept on running. No plug and kill switch off. I thought it was gonna blow. I twisted the throttle and it bogged out and died. Im thinking its my throttle and the carb. Can a carb do this if its not rebuilt right. The throttle is an aftermarket Twist. This thing has a mind of its own. Ive never seen something like that. Whers all the carb pro's?
    O yea the idle screw doesnt seem to do anything.
    84-85 Custom Tecate
    Dec 2002
    deer park, texas
    2,336
    besides air leaks i have had a problem when the carb is not getting enough fuel. my petcock was clogged. it would have to sit for about 10 seconds before it would start then when you cranked it up it would rev out. the kill switch wouldnt stop it. it would rev until the carb ran out of fuel which was only a couple of seconds. check your fuel filter lines and petcock. it is definatly worth a try.
    Apr 2003
    Central New York
    1,864
    petcock
    I definatly need a petcock it messed up so I took it aparty and made it so it is allways on. The filters were dirty also. Thank you.
    84-85 Custom Tecate
    Apr 2003
    Central New York
    1,864
    Hmm im Dumb
    It was the Idle screw.
    Im used to the screw being all the way in and backing it out to idle. This carb you have to screw it all the way out then screw it in. My friend figured it out. The Tecate Project is alive and I finally got to ride it after 8 years. Now I need to cut my Rear fender for the seat and its done. Pics soon to come I guess.
    84-85 Custom Tecate
    Jul 2003
    936
    that kill switch thing happened to me one time, it wound out so high and it wouldnt die, i got off the bike and ran, really...i thought the thing was gonna detonate, it turns out that it was because of the fuel flow
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
