Thread: doing a 200x top end need help
    200xkwit is offline Registered User Arm chair racerAt the back of the pack
    May 2004
    Rochester NY
    355
    My 200x is getting a new top end on its first bore. what I want to know is how do I set the timing when I put it back together..?? do I need an special tool?. Also I did some riding without my exhuast on so how can I make sure the exhuast valve is still good?. I mean it looks ok (little cruddy) and I shined a flashlight on the bottom to see if i could see any light showing through in the exhuast port. (I didnt see any). any suggestions?
    hmmm..
    Well i can tell you how to set the timing. First thing is to take the peep hole cover off the stator cover so you can see the marks on the flywheel. Then rotate engine until the letter T is lined up with the groove on the stator cover. Now comes the tricky part. Loosen the cam chain up and put the camshaft into place with the lobes facing down. The bolts should be vertical and a circle on the cam gear should be lined up with a a notch on the rocker cover. After you get all that installed you have to make line up the CDI with the F mark on the flywheel which is done pretty much the same way only you are looking at a line on the pick up thing ( Black box that is stationary). AND for the exhaust valve I would go ahead and take it out and look at it before you get it all back together and find out if it is burnt. Good luck!
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    If you are getting a new top end meaning a new piston, rings & wristpin then you should take the opportunity to have a valve job while it is apart. It will be money well spent, expecially if it has never been done before.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    Oswego, IL
    1,858
    how much is a valve job? what is it?
    1974 atc 90 project underway cuzzztom
    1985 atc 110 for sale
    84 200s all original got off the first and only owner
    new carb
    maybe putting my 200x cam in it but not sure
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    May 2002
    610
    I would stay away from running without the exhaust attached. That will speed up the burning of the exhaust valve.
    Sam from Florida
    1985 BIGRED $ 200X
    valve job
    take it to a machine shop and they will regrind the valve seats. Here in Ohio I had just 1 valve seat ground and it costed around 20 or so bucks so your looking around 50 chucks maybe.
    May 2002
    610
    Check with Ritter Cycle Racing (they advertise in the back of Dirtwheels) they did my 200x valves and did a nice job. $50. A little slow but solid.
    Sam from Florida
    1985 BIGRED $ 200X
