Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: help atc 500
    Nov 2002
    hinesville ga.
    200
    help atc 500/ now running
    today i tryed cracking my atc 500 project bike...when i kick it over i can only get one revolution out of it...do i have to add another head gasket or another gasket at the bottom of the cylinder...it will back fire but only kicks over once...any advice is accepted...
    Jun 2004
    Mississippi
    83
    Those 500's are a complete biatch to start. If you are out to make sure that it runs get sombody to pull you off. I had a cr500r dirtbike and that is prettymuch the way I started it anytime it was cold. Once it was warm I could start it but even then it was stilll hard.
    2000 Banshee: Modded out!!!
    1985 ATC 250R: Bone stock but not for long.
    1984 ATC 185S: Modded out!!
    1979 ATC 110: Stock execept fork extentions
    1984 ATC 110: Same as above
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Well, I have a XR500R Dirtbike, and it can not be started without using the compression relief valve. My bike has a small lever that mounts on the handlebars under the clutch lever. THe cable goes down to the right top side of the head. If im not mistaken it holds the exhaust valve open. Mine starts on the first kick after the compression stroke. Most of the time I get on the bike and slowly push the kickstart down until I feel resistance. Then I pull the valve open and hold it open, and kick it one time. This gets it off the compression stroke. Then I just kick it once and it fires off. It can not be cranked by a HUMAN!! unless its off the compression stroke. My wife actually tore ligaments in her ankle trying, by accident. She thought she had it off the compression stroke, but it took one more kick. She let it have it and tore ligaments. Im a big guy 6'3" and 285lbs and I cant come close to kickstarting in unless its off that compression stroke. Maybe you need to hook up a compression relief valve. Sounds like you dont have one.
    CLayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Mar 2004
    1,727
    It will also back fire a bit it you dont kick it over fast enough. Its more like a poping sound coming out of the muffler.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    May 2002
    Southeastern Wisconsin
    3,658
    Gasmask, is this a 2 or a 4 stroke?
    Mar 2004
    1,727
    Has to be a 4.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    May 2002
    3,658
    I've been gone for awhile so I may have missed an old post but why would it have to be a 4?
    Jun 2004
    Mississippi
    83
    It is a two-stroke.
    Jul 2004
    Okla.
    75
    my yz490 just gave me the same problem....it had water in the gas.....now it starts first kick.....
    May 2002
    3,658
    Thanks H.M.F.I.C., that's what I thought it was.
    Mar 2004
    1,727
    Sorry about that. The guy I was thinking about, converted his 350x 4 stroke to a 500 4 stroke. Mine is a 4 stroke.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Nov 2002
    hinesville ga.
    200
    it is a 1985 cr 500 2 stroke engine...i cleaned the gas tank out 3 day ago & it sat in the shed until today...fresh gas & 2 cycle oil. as you already know if i remove the spark plug i get all the revolutions i need, but when i put the spark plug in i only get one...is that cause buy to much compression.i remember reading one forum saying that they used 2 head gasket to lower the compression...
    Nov 2002
    hinesville ga.
    200
    Quote Originally Posted by OldSchoolin86
    2 stroke cr 500 honda
    Jul 2004
    Okla.
    75
    Quote Originally Posted by gasmask
    All that it took to make my perfect YZ backfire and not start was about 3 small drops of water in the float bowl.....I got just a couple of drops out of the tank too.....If thats not it then look for something that would cause it to be lean.....
    Jul 2004
    Okla.
    75
    u could also try starting fluid just to get it started the first time....
