Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: Pics of my 110 project
    Jun 2004
    Brazil, Indiana
    1,389
    the cap is for the tank to breath...if u turn it off it will go for a bit but then die cause it isnt getting any gas to the carb from the suction...u only turn it off it trailprotrailpro trike is not running...and if u tip over run p and turn it off...otherwise it will leak and can cause a fire...its happend to my friend and it doesnt look pretty afterwards
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Ripley Tn
    1,363
    I got a rare race frame for it and a super trapp pipe racing pipe to the frame is a 2inch extended bandito frame
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    St Clair County Michigan
    16
    Here is an update... Going well so far. Except the second coat of paint went on a little wet. The clear coat made it look alot better.
    Attached Thumbnails Attached Thumbnails 79_110.JPG   79_110_2.JPG   79_110_3.JPG   79_110_4.JPG   79_110_5.JPG
    Michael Darrell
    79' Honda ATC 110 (Trike Virgin)
    Jul 2004
    Here
    126
    Looks good, So what paint did you end up using?
    16
    Krylon Cherry Red for the tank and forks and headlamp. Krylon glossy black for the frame and Krylon Crome for the ring around the headlamp. I forget the actual name for the fenders but it was a paint for plastic. Can't remember the shade of red either.
    Michael Darrell
    Jul 2004
    Here
    126
    The krylon is great...I really like how the spray was a fine fan pattern, very easy to lay down. What did you use for clear?
    16
    I believe that was a Krylon clear coat also. I bought alot of paint this last week but I didn't buy all the same brand. I could be mistaken. I will check tonight.
    Michael Darrell
    16
    The chrome looked real nice. I am thinking about painting the rims chrome also.
    Michael Darrell
    16
    I am a little stumped on what I should do for the handle bars and tail lite bracket. They are both scuffed and a little rusty. any recomendations?
    Michael Darrell
    Jul 2004
    Here
    126
    Well the handle bars on the 70 that I freshened up were rusted all to hell. I took a 3M paint and rust remover pad...it works, stuck it in a drill and went at it, once it was down to a fine rust spotted look (if that makes sense) I sprayed it with rustoleum clear, the rust hasn't grown since and its been a couple months of humid weather, but it has been stored inside.
    You could always grind it down with the 3M pad and shoot it with rust converter, let it dry fully then sand and shoot with the chrome paint....thats how I did the wheels on the 70...ran out of rust converter and wanted to be done with it or I would have done the same to the handlebars...may still do it but I haven't felt inspired to mess with it lately.
    Lemme know what brand clear you used, I would appreciate it, I tested rustoluem clear on the krylon paint and it turned yellow and did not mix well, so if krylon makes clear I would like to get it, I checked their website and it wasn't and option so I just assumed they didn't make it. later
    16
    Thanks for the tip. I will start that this evening. I will let you know what clear coat I used. Thanks
    Michael Darrell
    Jul 2004
    Here
    126
    I better add that the 3m rust and paint remover pad will scratch the metal slightly, very fine scratches at that. I just went across the entire thing and it kinda give it a brushed aluminum look and dulled the shine slightly, the clear brought some of that back though. Good luck
    Jul 2004
    Here
    126
    Ever get a chance to see what clear you used?
