Results 1 to 8 of 8
Thread: plug fouls after riding, and cuts out at full throttle
    Dec 2002
    salem, nh
    1,339
    my 85 110 has a cobra pipe and uni filter with no lid. It'll start easy the first or second time but after you ride it, even for a short ride, it wont start again if you shut it off or stall it. When I pull the plug is all black and wet. Also I'm pretty sure it cuts out at full throttle unless the choak is all the way open. Can anyone help me as to why?
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Shrewsbury, West Virginia
    564
    If you have an aftermarket pipe, filter, and an open air box, you'll have to rejet the carb to compensate for the increased air flow. If the plug is black and wet, its too rich, which is really strange because usually when you add a pipe and increase the air flow you have to get richer jets. And if it doesn't bog when the choke is on all the way, its starving for fuel when the choke is off (lean) Try a new plug in it and see what color it is.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Jun 2004
    Brazil, Indiana
    1,389
    yea and if wat hondaatcman dont help adjust the fuel air mix screw to a leaner setting..sounds like its gettin to much fuel
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by 83185s
    I agree that can help but the air fuel screw only effects your carburation from idle to just before mid throttle.
    Oregon
    2,471
    Arrow
    Go buy few jet's size's up and some down , also 4 - 6 plugs .
    Clean the carb while your their .
    Oct 2006
    California
    many ways to lean out your band
    You slow jet is from idle to 1/4ths effect on your bike running. Your main jet is effected at 3/4ths or full. Your needle setting is 1/4ths to 3/4ths effect on performance. If your plug is wet, I would pop the top of the carb, take up the clip on your needle and check your plug gap. Also is this bike a 2 stroke or 4? Cobra only makes 4 stroke pipes I think. Any how, your mixture is effected by all of these things. Lean out your midrange and full throttle, then check your plug again. Someone want to tell him how to plug and chop and jet?
    Rittman, Ohio
    6,276
    Cmon, guys. This thread is from 2004!
    Jan 2005
    RI
    2,530
    i was gonna say.... oh #### killabeez is back!!! son of a
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
