Thread: Problème de Fumer
    chicoutimi
    20
    Exclamation Problème de Fumer
    Salut, mon 200m de Honda fait tjr de la fumer blanche qui sort du muffler.. j'Aimerais savoir qu,esse qui pourais faire sa et s'y c dengereux pour le moteur, et j'Aimerais savoir si c desaventageux d'enlever le pipe merci
    Jun 2003
    englishtown NJ
    2,676
    I don't speak french, but I know some spanish and what I got from it, was your 200m is smoking something white from the muffler. hint, you might get some help if you posted this in english. sounds like the rings are gone, redo the top end.
    chicoutimi
    20
    Exclamation With Smug
    Hi, Im french.. I don,t speak english correcty but.. i will trie... A With Smug get out of my Muffler .. What the probleme? He don,t looses oil but the level of oil fall.. it is dengerous for my engine? and it is a desaventage to have a straight pipe ? tk.. jA'i asseiller de parler anglais aumoin :P
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    You might loose a little power with a straight pipe. If its using oil and there is no leaks, its burning oil. This almost always indicates bad rings on the piston. It prob needs a new set of rings installed.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    chicoutimi
    20
    ok, thank you. Do you know were i can find a Owner manual for a honda 200 m ?
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Quote Originally Posted by honda200m
    You might have some luck on ebay. www.ebay.com
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
