Results 1 to 9 of 9
Thread: im new to this and need help
    xd 200x is offline Just Too Addicted Arm chair racerJust too addicted
    ok bought a honda atc the other day the frame is a 200x shock and all other parts are from a 200x. The guy says he put a 250cc motor in it. I finally got around to reading the plate on the motor says 192 cc. This thing has a pull start, and a trans without a hand operated clutch. I want to have the numbers on the block ran but the dealership is closed. I dont even know how many gears it has because once i got it out of first the rear bearings started making a sound so i parked it untill i could fix that. i realise i probly got ripped off but it was 200 bux so i said what the hell. if anyone has anyidea what the deal is with this thing help me out. please the dealership dosnt open till tuesday and im not going to be able to sleep till i find out.
    Jul 2004
    Alberta
    0
    It probably has a 200es(has a h/l lever) or a 200m (no h/l lever) engine. Many people have been building auto-x's(a 200x with a 200 bigred engine).
    it has no high low lever thanks how bad it it to have a 200m
    Does it look like this bike? This is my auto x. It has the auto clutch 200s motor in it. Does it have a rear brake? Post some pics of it.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Jul 2004
    Alberta
    0
    Quote Originally Posted by xd 200x
    I forgot to add it could have a 200s engine.
    yea it looks like that except it's more beat up the soonest i can get pics is tuesday. thanks for your help guys
    one more thng it's a chain drive with rear disk
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    I would say 200s. Probably has the original 200x rear disk brakes on it.
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    i found a atv junkyard today that had a complete 200x and a ton of 200x frames. got the exhaust the front pipe, the complete air box and pipes for it and the rear brake lever. the owner of this place said mine was most likey was a 200s also but my question is he said i could have the running 200x motor for 150 is it worth it to change the motor back if all i want to do is trail ride.
