Results 1 to 15 of 15
Thread: atc 90 and atc 70
    Aug 2004
    Ohio
    9
    atc 90 and atc 70
    has anyone ever put the atc 90 motor into the 70 frame?
    and does anyone know if the 90 even has that much more power than the 70?
    also this guy said its manual so thats seems pretty cool
    also the 90 motor is out of a 74
    heres the link
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
    chicoutimi
    20
    No you don't put a the atc 70 motor in a 90 frame, Do you have the atc 70 gear box?
    The atc90-70 is usualy the same but the atc 70 is 2 inch more little
    La Force des Québecois
    Aug 2004
    Ohio
    9
    i think you misunderstood what i was askin i was wondering if the atc 90 motor will bolt into a atc 70 frame.
    also yes i do have the the 70 gearbox, i have a complete running bike: its just a dawg
    You can swap it in but i believe u need to make a head bracket that goes to the frame,one of these days im gonna swap somethinginto my atc 70 just dont know what yet a 2 stroke would be cool though lol
    1983 Honda 110
    1967 Mustang
    Aug 2004
    Ohio
    9
    you can almost garantee me that all the otehr bolt up spots will work though, i just need to make one other mount?
    also do you know if the 90 motor will get the atc 70 movin quicker?
    thanks,
    Chris
    Houston,Texas
    1,044
    I should move at a good pace. I have a 110(not much difference from a 90), and it has good power for what it is. It would be cool having that power in a tiny 70.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Nov 2002
    Kirkville, NY
    3,831
    It can be done with a few mods. but again, why not just get a bigger trike. Just haveing more power is not going to make it a trail bike. And besides the 70 is a blast the way it is.
    If you want to still do the transplant then give Roy Franks an email (he doesn't check the boad on a regular basis). Here is a pic. of a 70 that he put a 125m engine in, a lot more power, hi-lo and electric start.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2004
    Here
    126
    you could go with the big bore kits for the atc70 that keep poping up on ebay...they are sold by this company on ebay .http://www.dratv.com/atc70honda.html ...comes with the cylinder/gaskets/piston/etc...they usually go for $90 +/-, a lot cheaper than on their website....that kit would put your 70 (72cc) at around 90cc....then you know its fresh...just a thought...good luck with your project
    Apr 2003
    Spanaway, WA
    1,244
    from what i understand you can do this swap in a day if you have the right tools and decent fabrication skills. personaly i'd do it with a 125 motor just for the electric start. i believe you have to get a 90 wiring harness or make one custom for it though.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Aug 2004
    Ohio
    9
    aight well i won a atc 70 head off ebay so im just gonna stay with the 70 motor and probally just go with the big bore kit but you guys keep saying you see it on ebay, i cant find it. if somone could paste a link in this tread that would be great.
    thanks,
    Chris
    also the reason im putting more power in the atc 70 is just cuz i like to screw around the yard and ride wheelies. it was alight when i got the bike but the power seems to be on a downward spiral.
    so. cal.
    first thing you need to do is to check the ignition timing, odds are that the timing is retarded. over time this will happen and adjustments need to be made. you can do this with the timing light for a car. neg and pos of devise to 12v batt, start bike, pull starter cover off, pull trigger of devise and check before you buy engine kits that still wont work well with retarded timing. I run my timing advanced about 1/16 before thefire mark.Give me a call anytime, i have everything you need along with a gauranty for the big-bore kits we install.
    Travis 951-795-1233
    Howdy's Avatar
    Celina, Ohio
    10,079
    Nothing like digging up a 16 month old thread. I am sure anything he needed has been done by now.
    Howdy
    Bigred200's Avatar
    Bigred200 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Livonia NY
    250
    lol.....Howdy your a trip.....lol
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    Quote Originally Posted by sterdy1
    Travis 951-795-1233
    70's dont have timing adjustment, its in the flywheel which is keyed, it aint movin!
    Perhaps check the condition of the points which is behind the flywheel.
    Sep 2005
    Lipetsk, Russia
    2,824
    Why would you want to do that anyway? It's gonna be fast and yet with it's 10 inch wheels it's going to handle like a brick. A really tippy brick.
    Good for drags, I suppose. If you're 9.
