Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Cracked Crankcase on 350X
    Aug 2004
    Port Dover, ON, CAN
    24
    sorry about that guys , but i finally figured out how to make the pictures smaller, so here is the picture of my 350x, as you will notice i think it has a 250R headlight on it so it looks a little different, but i am going to look around for a stock 350X headlight because they look pretty mean,and if I see one for cheap i will pick it up but it isn't bothering me too much yet. Tonite I just finished taking the motor out so it is all stripped down, now i just gotta wait for the cases to come in so i can get it rebuilt. dave
    Jun 2003
    South of Rochester, NY
    3,471
    Quote Originally Posted by dave_iggy
    Looks like a complete 250R front end... 350X was a leading axle. Is that seat say HONDA on the back? Is it mint? I have a mint 85 seat and am looking for a mint 86 seat like that. Let me know if you'd like to 'swap'. I got one of the last white 86 OEM fenders from HONDA before they went DISC. and all I have are 2 mint 85 seats. Would like one with 'ATC" on the side instead of '350X'
    As far as the side cases go, which one is broke? Usually it's over by the chain. The 85 and 86 should be interchangable. The clutch covers aren't, but you can swap out the clutch cable arms to swap them back and forth. (Been there... done that...) As far as the cable routing, the brackets from a 86 motor will mount on to a 85 motor and vise versa.
    If you are going to 'rebuild' the entire motor, it might be more economical to search for a crate motor on ebay. I picked up a fresh, never used motor for $800 (lil above average, but I made some great deals on other 350X NOS OEM parts from the same guy..) By the time you look at bearings, pistons, cams, valves, clutch plates, etc and a side case for yours, you can easily spend a chuck of cash getting up there! Sometimes, they even have the kickstarter, front sprocket/cover, oil cooler, and carbs on them!
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Aug 2004
    Port Dover, ON, CAN
    24
    that is a good point bruce to buy a new motor, when I ripped the motor out of the frame i noticed alot of stuff that was wrong like alot of stripped bolts, the case that is cracked is the left side case by the front sprocket, and also the main case, where the bottom motor mount is. How many pieces are to the case, 3 ?, a left side, right side, and a middle part, i am not sure, i haven't looked at it too closely. i just sent it to a guy that rebuilt my brother's motor, he is going to crack it open and see if the inside looks as bad as the outside of the motor. And these crate motors you were talking about, i saw one on ebay and they wanted 1400 dollars american, which is like around 2000 canadian money, and then 55 dollars US to ship it, and then they wouldn't even ship it to canada so i would have to go to the states, so i was wondering, do they all run about that kinda money. and lastly my seat has honda written on the back, if i am not mistaken, and nothing on the side of the seat, it is in good condition but has two small holes on it and the guy i bought it from has put nice blue tape on it so it looks pretty good. and you thought that my 350x has a 250R front end also? it could be , which makes me think, the steering stem bearing is very sloppy, but could that be because of the 250R front end, not fitting right on the 350X frame? if you wouldn't mind answering these questions it would be great
    dave
    markdb420's Avatar
    markdb420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Virginia Beach, VA
    413
    I have many 350x headlights. I have one on each of my 350x's and one of each on my 250R's. Wanna trade? Check the tight ness of the nut on the steering stem. I have seen the whole R front end on 350x's. It will work, you may need new bearings. Just let me know on the headlight.
    06 Yamaha Bruin 4x4
    04 TRX Rancher 400 AT 4x4 GScape
    86 ATC 250es Big Red
    84 ATC 200s (31 yrs running strong)
    13 F150 4x4 SuperCrew 5.0
    00 Excursion V-10 lifted with 35s
    ____________________________
    Gone
    07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
    Aug 2004
    Port Dover, ON, CAN
    24
    hey mark, i would love to trade that 250R headlight for a 350x one. Just to let you know it looks better on the picture than it does up close, all though it has no cracks or anything you can tell it has just been freshly spray painted, there are some little divots in it, it isn't perfectly smooth like it would from the factory, but the rubber straps to connect it to the forks are not broken at all, and the clear lens has no cracks. What does your 350x light look like?
    dave
    Aug 2004
    Port Dover, ON, CAN
    24
    oh and bruce i wasn't even thinking, but today I looked at my seat on the 350x and it has ATC written on the side, I didn't think it did, but i never really looked at it that closely. i was just thinking what you were talking about my seat having "atc" written on the side, and then i looked at it. and i also noticed it has three little holes in it not two. Does anyone know if you can fix up a couple tiny holes in a leather seat like that, other than putting a little tape on it?
    markdb420's Avatar
    May 2003
    Virginia Beach, VA
    413
    Well I have 3 very good and one that is in fair shape, it has been painted and the straps are good. It has the wiring that you'll need to splice back to your wiring harness. It has good lenses and good bulbs. That one is in similiar condition to yours.
    06 Yamaha Bruin 4x4
    Gone
    Phoenix, AZ.
    6,719
    Here's some headlights.
    Actually can you still buy these? They are kinda cool in a goofy looking kind of way.
    Jun 2003
    3,471
    Yes... there is some guy that keeps trying to sell a crate motor with like a $1,432 opening bid or something.... if you notice, it never sells!!!!
    I got mine for $800 which is about average, but made some great deals from the same guy on OEM fender, toolbox w/tools-jets from HONDA, rear axle, rotors, sprockets, CDI's, etc so it washes out some.
    I'll pass on the seat.... really looking for a mint '86 one.
    Thanks!
    Bruce
    Aug 2004
    Port Dover, ON, CAN
    24
    sounds good bruce, i figured you'd want one in mint shape, my 350x is going to be used for riding more than a showbike for now so the seat cover is still good enuf for that. thanks for advice on crate motors, the guy that i sent my motor to, said he would crack it open to see how bad it looks in side, and if it is going to be too much money to fix i will find a crate motor
    dave
