Since the 200x fork will bolt up to a 250sx shouldn't this bolt up to my big red? any reliability issues?
I need to either get a new front fork or do some machine work So I figured I would just get a fork to provide some more handling.
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
put one on my 84 200es. measure the length of the down tube to see if any shims are required... mikeOriginally Posted by conig
are you taking about the 200es or 250es?( I asume that he is talking about the 250es)
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
in his sig it says that he has an 85 250 big red so i figure thas what he's talkin about
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
yep 250es. I see people doing this with the 250sx but am alittle concerned about the weight of the big red.
maybe a 350X front would be more at home on the big red?I am just wondering if it would make it a chopper though?(high in the front)
85 Honda 200X
88 Honda CR 125
you can adjust the height of the trike by moving the fork in the tripples. and the defination of a chopper is adding rake to the front end. you have to "chop" the frame to rake it, hence the term "chopper".
Tim is the name
85 350X(86 motor)
83 200X(stripped down for a total rebuild)
85 200S(project)
