Suzuki LT 250r Quadracer crankshaft question
Ok, Wiseco sells a crank/rod assembly that includes a new trued crank, a "Hot Rod" connecting rod kit, wrist pin bearing and inner crank webs. They say its for an '88-'92 model and I have an '87. I really want this kit and don't understand why its not listed for an '87 model because the tranny cases and transmission are the same, the cylinder is a little different on the '87 from the '88 and up..but they are the same stroke. Maybe the crank bearings are different, but I can order the '88 crank bearings and seals since the cases are the same. Does anyone know for sure this will work or maybe someone has already installed this kit on an '87 model?
Any advice would be greatly appreciated. Thanks!!
Justin ~hondaATCman~
'82 Honda ATC 110
'81 Honda ATC 250r (Summer Project)
'87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
'03 Yamaha Big Bear 400 4x4
'85 Ford Bronco II 4x4 2.8 V6
