Results 1 to 15 of 15
Thread: 1983 Honda 185s Problems...
    Jan 2004
    Flint (Clio) Michigan
    67
    The problem is it seems that once it gets hot it dies. I can let it cool down and one pull its starts again, but once it gets hot it dies again. I swapped coils today but still the same thing.Any suggestions?? I'm open to anything. Thanks.
    1985 Kawasaki Klt 160 (SOLD)
    1983 Honda 185s (SOLD)
    2001 Kawasaki Lakota Sport 300
    1993 Kawasaki Bayou 220
    2005 SUNL SLA-150KL Quad (SOLD)
    Jun 2004
    Brazil, Indiana
    1,389
    r u runnin on full choke or none at all? my prob was i was runnin on full and didnt know it cause when i turned it off i thouhgt i turned it on cause it died..but once it got warm i turned it on as i thouhgt it actually turned it off and it ran fine...sounds confusing huh? i thought it did to me lol...simpler terms...just make sure uve got the choke off not on
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Jan 2004
    67
    it takes the choke to start.........but the choke is turned off after it does....
    what does the spark plug look like?I would say that it is the coil or the petcock is clogged,try putting some new fuel line on and when you have the fuel line off try turning the gas on and see if you have anything coming out.
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Jan 2004
    67
    We put new fuel line on yesterday.........There is a good stream coming out. I'll check the plug.
    Jan 2004
    67
    I checked the plug......its black and dry.
    Apr 2002
    s.w. michigan
    6,498
    troubles
    seems to me i remember dry/black soot on the plug as a indicator of electrical problem ( weak spark ).
    looking thru the trounble shooting guidlines in my clymers and honda manuals it's saying thats a possiblity too.
    i don't know where i seen the 8 different types of plug fouling before and that was what i was trying to find as i leafed thru the manuals.
    it also said to check for air leak after the carb ( intake side ) and also check timing. but what i'm reading kinda points to the c.d.i. or excitor coil.
    john
    Jan 2004
    67
    Is there any way to test the CDI or coil?
    Apr 2002
    s.w. michigan
    6,498
    specs
    as i was looking up specs for testing the coil i come across the page i had seen along time ago about plugs. there are 9 different types of fouling and it tells in detain the associated problems in logical order.
    yours sounds to me like carbon fouled. identfied by dry fluffy carbon deposits. causes in order of most likely are (1) too cold of plug (2) weak ignition (3) dirty air filter (4) to rich of fuel mixture or excessive idling.
    says plug can be cleaned ( go figure - lol )
    anyway ,,, to test out a c.d.i. is the most major pain in the butt thing to do ( been there- done that ) ,,,, all readings are to infinity on the 14 - 15 check points. you are taking a multi tester and touching each one of the male prongs to each other ,,, it's a real pain in the arse.
    now the good news ,,, coils are easy to check.
    primary coil for your 185-s is 0.2 - 0.8 ohms
    secondary coil is 8 - 15 K ( again ,,,, ohms or resistance value )
    john
    Jun 2004
    Brazil, Indiana
    1,389
    hey that sounds like my problem now! it just started..it will only run on full choke now for some reason...even tho it worked yesterday...my plug is also black and dry i turned down the fuel air mix and it started doin that but when i turned it back up to where i had it it still did the same..before it was wet and dry now its black and dry..im thinkin electrical..ive got an autolite plug in it right now ...maybe i should get a ngk for it..ive got a champion somehwere brand new so ill try it out and see what happens..i cant see y it does this tho..anyway mine started that today
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    Jan 2004
    67
    It was the primary coil.........I have a new one ordered.
    Jun 2004
    Brazil, Indiana
    1,389
    nice to see u found trailprotrailpro problem..mine runs fine now i guess i didnt give it enouhg time for the carb to go back to how it was after i reset the fuel air mix...it burns and leaks oil really bad tho...not good its cause i need new gaskets...anyone know where i can get a real cheap set of top end gaskets? like under 20?
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    try this http://www.dansmc.com/spark_plugs/sp...s_catalog.html
    85 Honda 200X
    88 Honda CR 125
    Jan 2004
    67
    83185s....... www.hyperparts.com top end gasket set for yours..$12.81
    Jun 2004
    Brazil, Indiana
    1,389
    thanks man thats the cheapest yet!!! thatll help me out alot on money!!
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
