Results 1 to 8 of 8
Thread: float level
    Watertown, New York 13601
    3,382
    float level
    Here is a stupid question but how do you adjust the float on a 85 tri-z carb and what is the stock setting? If the setting is wrong will it cause tto foul plugs? I am having trouble fouling plugs, my main jet size is stock 470 and my needle clip is stock on the 3rd notch, what is my problem?
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Aug 2004
    Ab Canada
    4,368
    befor messin around with the floats move the needle clip up a notch or 2 and see if that helps the plug should be a tanish coulor i belive.
    1985 Tri-Z-
    3,382
    Quote Originally Posted by My trike Sucks
    Will it be safe going leaner then stock settings?
    2006 YFZ 450
    Front royal, va
    2,186
    31.5 mm. is the float setting
    3,382
    Quote Originally Posted by 03 ORANGE SHEE
    How do i know were it's at and how do adjust it?
    2006 YFZ 450
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Get a ruler with mm's on it,then measure from the carb body to the end of the float.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Aug 2004
    Ab Canada
    4,368
    i still think its just running rich from what you say...you can tell if the floats are too high by putting the bike on levle ground and turning the gas on...if gas starts comin out of a little tube comin out of the bottem of the carb...the over flow..you know there 2 high..i run my trike at the leanest notch and it runs great..it all depends on the elavation that your on ...the stock settings are for where ever in japan they made it lol..just try movin the clip up 1 by 1 untill it stops foulin plugs just my 0.2 cents
    1985 Tri-Z-
    3,382
    No gas is running out of the tube. I will try moving the clip up 1 notch to the 2nd groove.
    2006 YFZ 450
