Thread: Is the Big Red Rear Differential Same as TRX 250'S
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Anyone know if the rear differential in a 250 big red and a trx 250 are the same. Thanks the info would be very helpful.
    Clayw
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Howdy's Avatar
    Celina, Ohio
    10,079
    A couple years ago I found out the cases are slightly different. To use a ATC dif on a TRX you need to machine out a little of the case where the left side tube slides in. If your putting a TRX dif onto a ATC then you should be able to just bolt it up and go. I am not 100% sure if the gears are the same, but on the one I did ( ATC to a TRX ) it worked just fine.
    Howdy
    Mar 2004
    1,727
    Thanks Howdy.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    Clay any idea what the gear ratio is on a trx 250?
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Mar 2004
    1,727
    No idea. Sorry I cant be of any more help.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
