Results 1 to 8 of 8
Thread: tri-moto carb help
    Mar 2004
    Fond du lac,WI
    658
    tri-moto carb help
    my carb is not getting enough air how do i adjust this? its a 1983 200.
    Jul 2004
    minnesota
    689
    clean the airfilter out
    Mar 2004
    Fond du lac,WI
    658
    i took the air filter out and it is the same
    Mar 2004
    Fond du lac,WI
    658
    can anyone help?
    Nov 2002
    Kirkville, NY
    3,831
    How do you know that it isn't getting enought air? Maybe it is just getting too much gas?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    dude...i feel for ya. i had so many problems with mine i bought a brand new one. ran good for a couple days then crappy again. i agree with hot rod. clean or replace the air filter. also buy a clymer manual and follow the instructions to clean the carb.
    YAMAHA'S: 84 225DXL
    04 POLARIS SCRAMBLER 500 4X4
    05 kazuma 50
    Aug 2004
    PA
    190
    Mine is the same way. Sometimes it won't start, and the second I take out the air cleaner, it fires first pull. I don't even have to choke it at all.
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    It might be getting too much gas that when you take the filter off everything balances out. Check the posistion of the clip on the needle valve and that you have the right jet sizes. If you haven't cleaned your carb out you may want to do that too. Just shoot a little carb cleaner in every hole you can find. Take out the idle screw and the air pilot screw and clean those as well. Good luck.
    Anyone know of a new project machine for me around Wisconsin?
