Results 1 to 14 of 14
Thread: My BigRed Electroplating
    Mar 2003
    Australia
    1,919
    Gday,
    In restoring my bigred i opted to electroplate all my fastners, bolts clamps etc, so they would look nice and new. The setup is a simple bath with chemical, an electrical current, nickel anodes and a heat source. The pics kind of self explain. I payed 150 Aus dollars for it and at first it dident work out, so i kept at it and got a smaller tank and she works a treat now! Its gonna take me a few weeks to plate all this stuff but itll get done nonetheless and should look sweet.
    Here are a few sample pics for you all. The brake cam in the first pic is before and the second one is after...
    Matt
    Attached Thumbnails Attached Thumbnails before plating cam brake.JPG   after plating cam brake.JPG   plating bath in order.JPG   Plated Stuff.JPG
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Minnesota
    790
    Looks awesome Matt! Thanks for posting those. ttyl
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    So with all these little sparkly things on your trike, are you ever gonna ride it and get it dirty? (j/k) Nice job Matt.
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Aug 2004
    Ab Canada
    4,368
    looks nice..could you do that with like a head or cylender..or is it sumtin that actually cooks onto it im a bit confused
    1985 Tri-Z-
    Mar 2003
    Australia
    1,919
    You could do it to a cylinder off a 70, 90 or 110 cause they are steel. It cant plate alloys, well not that ive tried....It is not baked on but it is transfered through an electrical current, the nickel comes off the anodes. It is a very tough finish.
    Matt
    Jun 2003
    stockton nsw
    85
    it is anidizing for steel's...but for the head ive seen some adds down on the central coast for places that anidize heads and cylinders...youl haveta check into it
    1982 Suzuki Sierra 1L - Nissan MQ axles and 38" TSL Swampers
    1982 LWB SIII Stage one Land Rover Tray Back- 4BD1 Isuzu powah!
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    "Electric current????" How much do you use Matt?
    12 volt battery, 110v or 220v mains.
    As a matter of interest what is the current used in Australia. 110 or 220 or 240 ???
    Reno,Nevada
    433
    You can get a quick intorduction in "Electroplating" by clicking this link http://www.caswellplating.com/movies/index.html# Look for the "How to Electroplate" flash file.
    I believe most of the home plating kits use a 6 volt lantern battery or a power supply that puts out 6 volts.
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    99 Honda XR250R
    broook's Avatar
    Mar 2003
    Newfoundland
    207
    Good site. Thanks.
    Mar 2003
    Australia
    1,919
    Hey Brook, we use 240 volts. Yes the power supply is mainly used on 6 volts but is adjustable to suit different loads of plating.
    Matt
    Aug 2004
    Ab Canada
    4,368
    soo...if you used it on a cylender though it would wreck the slever unless you did it then got it bored??
    1985 Tri-Z-
    Reno,Nevada
    433
    Are you wanting to plate the inside or outside of the cylinder? If you want to do the outside you could always bolt a head onto the cylinder and plate it upside down in the tub. Thats how I would do it.
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    99 Honda XR250R
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by renotrikeguy
    heh never thought of it that way..
    1985 Tri-Z-
    Jan 2004
    0
    2, 84' 200ES's for sale?!
    Quote Originally Posted by PowerTrike
    How much are you lookin' to get for the two ES's? I'm interested in one if the price is right.
    Bill
